New Topic New Reply
Author: Subject: Steering Rack Mounts
Michael
posted on 12/11/10 at 09:03 PM Reply With Quote
I had my IVA last Friday, and failed on steering rack mounts required bracing.
Just wondered if anyone had pictures of theirs that have gone through IVA.
Thanks.
skodaman
posted on 13/11/10 at 12:10 AM Reply With Quote
What mounts are you using and where exactly do they want it bracing?
Skodaman
RichardK
posted on 13/11/10 at 08:51 AM Reply With Quote
Do they have a diagonal like mine? Wondering if that is what he meant
Also the back of the mounting plate is bent back down to attach to the chassis so the bracket itself is an L shape.
You got any pictures of the offending area? Could help us find a solution.
Rich
P.S Went through sva not iva if that makes any difference.
[Edited on 13/11/10 by RichardK]
Gallery updated 11/01/2011
Michael
posted on 13/11/10 at 04:56 PM Reply With Quote
I saw the Haynes Roadster has a diagonal too.
He wants a nut under the bracket so the bolt can not pull through as it is currently on a threaded hole with lock washers.
I believe he wants the brace to stop the mounts twisting back if under strain.
ShaunB
posted on 14/11/10 at 09:27 PM Reply With Quote
A previous owner cut the diagonal brace out of my rack brackets presumably to save weight, but an eagle eyed scrutineer pointed out the flex he could see when moving the steering wheel when stationary. I'm about to weld a diagonal brace back in again! Note that my original brace only braced the nearside bracket, presumably that was enough.
You definitely want longer bolts with a nyloc on it, those brackets are all that locates the rack laterally - you really don't want a bracket breaking loose at speed
Shaun.
Michael
posted on 15/11/10 at 10:01 PM Reply With Quote
Hi
Yes we looked at it yesterday and started remaking the brackets, with nuts and bolts holding the rack to it.
I looked at the diagonal brace design and can see it will hold the rack mount from sideways movement when steering.
We are going to fit that onto mine when the other brackets are done. I assume this is what they want.
The brackets are 6mm thick so are realy solid.
New Topic New Reply
