dnmalc
posted on 28/11/10 at 10:52 PM |
Checks after a crash
My daughter has slid her starlet off a corner due to mud left by a happy farmer and impacted the rear wheel and wing with a large post. I have manged
to beat the wing into something that resembles the original form but I want to check to establish there is not more serious damage. I have checked the
inner wings and suspension mounts for any rippling of the metal and all looks good and I was planning tomorrow to check the rear camber and have all
four wheels tracked. My question is should I have anything else checked?
mookaloid
posted on 28/11/10 at 11:40 PM |
sounds about right
stevebubs
posted on 28/11/10 at 11:44 PM |
wheel balance...
daviep
posted on 28/11/10 at 11:54 PM |
Drive it and see if it feels alright, follow somebody else driving it and see if it drives straight or crabs.
Davie
RazMan
posted on 29/11/10 at 12:27 AM |
4 wheel alignment will show up any damage straight away
Raz
GMPMotorsport
posted on 29/11/10 at 09:50 AM |
4 Wheel alignment is the best thing for checking that all is ok, but would do wheel balance on that wheel in case it's buckled a bit.
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
nludkin
posted on 29/11/10 at 01:52 PM |
Was there signage up to warn of the mud? I vaguely remember a radio debate a while back where it was saying that farmers can be held accountable for
accidents if they don't make an effort to warn drivers?
Ninehigh
posted on 29/11/10 at 05:38 PM |
It's illegal to deposit mud onto the road
From my HGV theory test
SteveWalker
posted on 29/11/10 at 07:31 PM |
My car was once rear-ended while stationary at a zebra crossing - as if that wasn't enough to make it clear whose fault it was, the driver
admitted it in writing Anyway, the point was that the car had to have bodywork repairs done (and they were done well), but within weeks, both the
exhaust and a fuel line failed - they were corroded, but I'm pretty sure that the impact accelerated failure markedly.
PSpirine
posted on 29/11/10 at 07:42 PM |
I've slid my car into a grass verge/mud bank at about 50mph (thanks ice patch on an otherwise gritted road!)
I got a 1" crack on the bottom of the bumper and that wheel got knocked out of balance (I think one of the weights got knocked off). You can
usually tell if it's something serious as there will be a noticeable wobble or pull.
4 wheel alignment will definitely sort it out.
I'd say at the rear an impact is more obvious (you can see whether any of the beam mounts have bent etc.). On the front you often get a very
slight bend in the tie-rod or wishbone and you can't see it until you do tracking/alignment.
