MK9R
| posted on 17/12/10 at 04:11 PM |
DIY/locost tube notcher?
I need to join two 22mm tubes and can't justify buying a proper tube notcher for 2 joints, any suggestions on a locost version?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
interestedparty
| posted on 17/12/10 at 04:20 PM |
There's some software about somewhere that let's you print out the shape. You cut the shape out on paper with scissors, then you wrap the
paper around the tube and it shows you where to cut with angle grinder or whatever.
MK9R
| posted on 17/12/10 at 04:25 PM |
Quality! Will have a google. Any idea what it was called?
Cheers Austen
RGB car number 9
www.trackace.co.uk
Neville Jones
| posted on 17/12/10 at 04:27 PM |
Holesaw in the drill press. Clamp the tubes to an angle plate.
Software is called 'Tubemitre'.
Nev.
[Edited on 17/12/10 by Neville Jones]
MikeR
| posted on 17/12/10 at 04:40 PM |
there is better software for making bike frames - i can't remember what its called unfortunately. Try lots of googles for tube mitre, bike frame
etc and you'll find it. Does gussets and all sorts.
goodguydrew
| posted on 17/12/10 at 04:43 PM |
I used it, excellent little program.
zilspeed
| posted on 17/12/10 at 05:11 PM |
Just attack it with your angle grinder and edge up to a good fit.
A felt marker is good for refining where the bits need to come off.
Won't take long at all, epsecially in 22mm.
I did a couple of braces onto a 48mm roll bar and other than being time consuming, it was just about patience.
jacko
| posted on 17/12/10 at 06:00 PM |
How about a hacksaw and round file OLD SCHOOL
liam.mccaffrey
| posted on 17/12/10 at 06:02 PM |
Before I got my notcher I used to do it with a BIG half round file.
Build Blog
Build Photo Album
marcjagman
| posted on 17/12/10 at 06:28 PM |
Try here http://gtslocost.locostsites.co.uk/
designer
| posted on 17/12/10 at 07:35 PM |
Tubemitre, free download, as said before.
MikeR
| posted on 18/12/10 at 12:10 AM |
linky to bike one that does lots of fancy stuff -> http://www.cycle-frames.com/bicycle-frame-tubing/Tabbed-Tube-Notcher.html
andylancaster3000
| posted on 19/12/10 at 04:40 PM |
2nd the by hand method. If its only one joint a tube notcher is not worth it. I've helped do a couple of chassis solely made of round tube with
a decent hacksaw and large (good quality) radius round file.
andkilde
| posted on 20/12/10 at 08:55 PM |
Try here.
Cheers, Ted
MK9R
| posted on 21/12/10 at 11:22 PM |
cheers all, used tubemitre and it worked a treat
Cheers Austen
RGB car number 9
www.trackace.co.uk
dave r
| posted on 22/12/10 at 06:54 AM |
anyone got anything that will make a template, same as tubemitre, but for round tube meeting a flat plate at a specific angle ?
its been so long since i did tech drawing at skool, i may struggle to remember how to do it by hand!
dave
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
kb58
| posted on 22/12/10 at 02:29 PM |
Oh come on now... measure the angle difference between the round tube and square plate, draw matching angle on round tube, cut. Presto.
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
