BazzaMonty
| posted on 5/2/11 at 10:34 AM |
P-Clip sizes
Hi Guys
What size of P clips do you use for copper brake pipe and copper fuel pipe, I will be using the rubber covered type. I know wot you lot will be
thinking ( why dosent he just measure them!!!! ) and my answer is i am working in Nigeria at the moment ( yes......NIGERIA......sh#t hole of a place )
Picking my MNR up when i return home in 2 wks time and want to get some stuff ordered online. Thanks guys
Baz
chrisbeale
| posted on 5/2/11 at 10:53 AM |
i think they are about a size 8, possibly a 7.
| posted on 5/2/11 at 11:20 AM |
Better to use proper OEM style clips rather than P Clips also I would suggest you use Kunifer brake pipe rather than copper.
Madinventions
| posted on 5/2/11 at 12:07 PM |
I used these from RS Components.
Ed.
View my band website:
http://www.shadowlight.org.uk
BazzaMonty
| posted on 5/2/11 at 01:17 PM |
Ed, Yes this is the type i will be using. I have found them on a website www.shop4fastners.co.uk and seem very cheap. I am going to order 5mm for the
brake lines and 7mm for the fuel lines unless anybody tells me different.
Cheers, Baz
| posted on 5/2/11 at 01:37 PM |
Cheers, Baz
Better bet would be the proper brake/fuel pipe type suggested by B.T . Made for the job, lighter and cheaper.
BazzaMonty
posted on 5/2/11 at 02:07 PM |
Without going to a dealer, where would i be able to buy OEM style clips? the p-clips i am looking at are only £3.49 + vat for 20, which i thought is
very cheap compared to some kitcar related shops where they are about £7 for 5!!
| posted on 5/2/11 at 03:48 PM |
Check out places like Car Builders Solutions, Europa Spares , Demon Tweeks etc or wait until you can get to a show like Stoneleigh , there will be
loads of useful stuff there. Your local motor factors will probably be able to help.
Mike Wood
| posted on 21/2/11 at 08:48 AM |
Contact Automec - www.atomic.co.uk, they should have the right clips. It might be cheaper to buy a complete car kit from them, telling them what
vehicle your callipers and rear axle are from and then shortening the front to rear pipe
Also for clips try Merlin Motorsport, Trident Racing Supplies or Raceparts
Mike
Mike Wood
| posted on 21/2/11 at 08:52 AM |
Sorry about my auto spell checker, try www.automec.co.uk (not atomic!)
Mike
