PuppiesBalls
| posted on 7/2/11 at 09:59 AM |
Track rod ends, Only 7 turns!
Good morning gents, I fitted my track rod ends this weekend, i noticed that there only threadded on by 7 full turns, is this going to be enough?
its the standard m14x2 thread which i think means that there screwed on about 14mm (7turns times pitch)
Does anybody know if thats enough?
loggyboy
| posted on 7/2/11 at 10:27 AM |
14mm seams loads to me, even at 1.5 pitch, 7 turns would seem adequate to me, (famous last words).
| posted on 7/2/11 at 10:32 AM |
The rule of thumb I was taught (if both threaded parts are made of the same material) is 65% of the nominal diameter should be engaged or a minimum of
5 turns, whichever the greater i.e. for M14 it would be 14 * 0.65 = 9.1mm, but with a 2 mm pitch 5 turns is 10mm which should be the minimum. Seems
you have an adequate margin!
PuppiesBalls
| posted on 7/2/11 at 10:36 AM |
Awesome! seems im just being a bit of a worryguts
coyoteboy
| posted on 7/2/11 at 10:50 AM |
PuppiesBalls
| posted on 7/2/11 at 10:56 AM |
Neville Jones
| posted on 7/2/11 at 12:00 PM |
My 'rule of thumb' that I was taught, was that you should have a minimum of the bolt diameter in the female thread.
Not all thumbs are the same, as it appears.
Nev.
| posted on 7/2/11 at 01:45 PM |
Nev.
An M14 full nut only ~11mm deep, so that rule would be impossible...
coyoteboy
| posted on 7/2/11 at 03:46 PM |
Personally I prefer a much deeper insertion on something that's going to take bending loads in odd circumstances, the deeper the insertion the
less chance of splitting the end of the female side of things in an impact.
| posted on 24/2/11 at 08:24 AM |
Theory says no bending loads on a track rod provided it is 100% straight but it is a strut in compression with this in mind I would regard
7 turns at 2mm pitch is just about acceptable but it leaves zero margin for adjustment.
[Edited on 24/2/11 by britishtrident]
