calybusa
| posted on 3/7/04 at 12:57 AM |
my garage
Need some advice im kind new to all this and wanted a few thoughts from you guys with experience. i have a garage roughly 16ft by 8ft and 6.5"
high. do you guys think this space is sufficient to build a locost car in?? Heres a pic of the garage course the junk will be cleared
calybusa
| posted on 3/7/04 at 12:58 AM |
sorry i didnt think the picture would turn out that big
blueshift
| posted on 3/7/04 at 01:35 AM |
I'm not very good at feet and inches.. and I'm drunk.. but I figure if you can fit a locost in it with 6 inches all around, it's
enough space at a pinch. anything more is gravy (like space for Stuff or workbench, welder etc).
scoobyis2cool
| posted on 3/7/04 at 01:59 AM |
Have you got a driveway or similar you can use? Once you've got the wheels on you could wheel it out for more space if you find you
haven't got enough space (weather permitting)
Pete
blueshift
| posted on 3/7/04 at 02:55 AM |
oh yeah. some people (mark allanson?) have assembled their cars outside, you could keep it under a tarp or something, and use the garage as a
workshop. possible?
we've got a smallish single garage, not sure of the dimensions. we have our build table built over the engine at the moment, with enough room
for a workbench at the end and some shelving down the sides. all other bits and bobs are scattered around the house / shed etc
Chris_R
| posted on 3/7/04 at 09:30 AM |
I have a garage of similar dimensions and am coping alright. I found suspending a bench on the rear wall gives you ample space to work whilst still
allowing you to fit a whole sierra in. You'll have enough space to erect a flat work surface and still store parts beneath that and your
bench.
The only problems I have are light and electricity. Light in the summer is no problem, but electricity is a bit of a pain. I tried hooking up my MIG
to a generator, but the MIG didn't want to know. My part finished chassis is now at my parents house were electricity is in abundance. It'll
prolly be there for a couple of months before coming home. :-)
Good luck with the build though.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Chris_R
| posted on 3/7/04 at 09:31 AM |
underside.
Mark Allanson
| posted on 3/7/04 at 10:22 AM |
Lucky bastard!!
| posted on 3/7/04 at 11:23 AM |
With regard to the garage...
10ltrs of white emulsion on those walls should give you 50% more reflected light and would cost less than a tenner! One strip light in the centre
(preferably two, one either side is better!)
You deffo need a bench with a decent vice... looks like we did our build in comparative luxury... No heat, but light and power!
Mark - so you have a snow machine   show off!
fatfranky
| posted on 3/7/04 at 11:53 AM |
Firstly I've never built a Locost - Yet! but have done other car projects.
I've seen various people prepare the "big lump" ie. bodyshell (or in this case Chassis) and then have no room left to work on other
parts because yhey are tripping over their bodyshell (often damaging it).
The approach i prefer is to prepare the smaller parts, such as wishbones or overhauling the donor components replacing bearings, seals brake linings
etc. these parts can then be stored away in shed cupboard loft etc. and then just used when required.
When you do build you can then very quickly get it to a stage where you can at least wheel it in and out of the garage to allow room to work.
I read an aricle in a magazine years ago about equiping a very basic council lock up type garage and included such common sense items such as using an
old 12v battery to have some light and an old calor gas heater so you can at least stay warm in winter, i've probably still got it and can dig
it out if required.
Alan B
| posted on 3/7/04 at 12:18 PM |
Hey Franky....
Good logic there.....that does make more sense...probably needs a lot of discpline not to make the frame first, but definitely worth
considering...
Oh yeah....Welcome to the madhouse..
calybusa
| posted on 3/7/04 at 02:19 PM |
hey guys thanx for your thought you've been real helpful i've got plenty of garden space so i'll be doing most work outside.
calybusa
| posted on 3/7/04 at 02:21 PM |
hey could u dig out the piece of council thing if its not too much of a hassel, cheers
Chris_R
| posted on 3/7/04 at 03:39 PM |
have to agree with the paint suggestion. It does make it much lighter.
blueshift
| posted on 4/7/04 at 01:00 AM |
a quick me too. got a load of cheap paint and bits from wilko, white garage is lighter and also feels nicer to work in. cleaner and more productive,
rather than grubby mismatched bricks and mortar.
mangogrooveworkshop
| posted on 4/7/04 at 04:09 PM |
Im a bit tight for space in a single but better than SCOTLAD who did his on a patio in a scottish winter. Hardcore!
We got a shed to store the bits in then bring them to the work area for assembly
[Edited on 4-7-04 by mangogrooveworkshop]
macspeedy
| posted on 4/7/04 at 06:13 PM |
not much room plenty of bench and scottish weather!
millenniumtree
| posted on 5/7/04 at 05:40 AM |
Ooh ooh!! I want your place! We live in an apartment complex, with NO garage, NO patio, and a strict policy against doing ANYTHING mechanical to
your car in the parking lots.
I took my spark plugs out one day, and got yelled at for it. I SO MUCH wanted to say "This isn't mechanical, it's
electrical!!"
My best bet is a relative or friend's house, or cleaning/storing the parts in the closet before building the frame. The engine is in my
daily driver, so I would just have to wait as long as possible to build the frame and buy the tranny/axles.
Terrapin_racing
| posted on 5/7/04 at 12:21 PM |
You could get some 4x2 beams (use galv. brackets from builders merchant) and make a structure to support the body panels near the roof whilst using
the floor space. White paint is a must for visibility. Good floor/concrete paint (I prefer International floor paints grey - B&Q) will make those
droped nuts/bolts easier to find as building progresses.
fatfranky
| posted on 5/7/04 at 05:46 PM |
As requested i've copied the magazine article i referred to earlier and have put it as a new post in the tools section.
For what it's worth after my original comments i looked at Chris_R's build site and his garage appears to be exactly as described.
I'm also saying this to stick up for a fellow Geordie in the face of all you southerners.
Hope the article is of some help
thekafer
| posted on 5/7/04 at 05:47 PM |
I envy anyone with any garage..I built my frame in a hanger at work but we've since sold that hanger..I also live in an apartment but should be
getting a house soon. I have plans to use an etching floor paint as well because it makes it much brighter and is nicer to "roll around"
on.
Our hangers have painted floors and it sold me....
...outside in a Scottish winter!!!! ....now thats really wanting it!!!!..
Fletch,
I'd rather have a bottle in front of me than a frontal labotomy...
Chris_R
| posted on 5/7/04 at 08:59 PM |
Have looked into 12v lighting as I don't like running my generator for extended periods (being bang in the middle of a housing estate).
I'd hoped that floor paint would be a good idea, but to be honest I can't tell yet. The photo on the previous page shows a large tin at
the front left of the garage, which still contains all the floor paint that arrived in it. Unfortunately there's too much in the garage to give
it the twice over. Will let you know if I ever get round to using it.
suparuss
| posted on 6/7/04 at 05:48 PM |
ive used leyland red floor paint in my cellar, im not sure if its cos id only concreted the cellar floor 3 days prior to painting or cos of the rising
damp, but if it gets even a little bit of standing water on it, it starts to dissolve!
probably just cos of the uncured concrete though!
cant wait to get round to ripping my garage down and rebuild it ABSOLUTELY HUGE! Yippeeee. at the moment my 'slide over' door hits the
ceiling and dislodges from the roller groove things and goes all cockeyed!
calybusa
| posted on 11/7/04 at 09:44 PM |
i guess i dont have it so bad!!!
liam.mccaffrey
| posted on 11/7/04 at 10:54 PM |
i am building mine in a 20' shipping container which is in my garden . am having 3 phase put in it on tuesday then gas heater and will have a
fantastic little workshop. am having 3 phase cos i have a lathe and miller
Build Blog
Build Photo Album
