Author: Subject: nissan ca18det wiring
vtecmike
posted on 16/3/11 at 09:19 PM Reply With Quote
hi,
can anyone help me out with wiring a nissan ca18det turbo engine into my haynes roadster, as im useess at wiring!
ive got the complet nissan so ive got all the looms.
ive got the ecu and engine loom separeted fine, its the starter loom i dont understand ie for the starter motor, alt and fuel pump, also how do you get power to the ecu?
the car is only for track use ,so will only need a button for starting.
thanks mike
austin man
posted on 16/3/11 at 09:27 PM Reply With Quote
I believe DRC Indy has fitted the same to his MK Indy
DRC INDY 7
posted on 16/3/11 at 09:33 PM Reply With Quote
Not quite mines a later sr20det but the ca18det is simple to do just have a look on line there are wiring diagrams for that engine
Puddle Dodgers Club
vtecmike
posted on 16/3/11 at 09:40 PM Reply With Quote
ive got wiring diagrams , just have trouble understanding them!
mike
deezee
posted on 17/3/11 at 12:20 PM Reply With Quote
Originally posted by vtecmike
hi,
thanks mike
Are you making a new fuse box, or reusing the loom and fusebox from the Nissan? If you wanted to make life easier, I'd just remove all the extras from your fusebox, then modify the cable lengths to suit. Would save a lot of hassle if you aren't comfortable with making a bespoke loom.
DRC INDY 7
posted on 21/3/11 at 08:25 PM Reply With Quote
Thats all i have done used the engine loom from the nissan at married it up with the loom on the car by doing it that way its just various power and earths ie battery feed, ignition only feed and start only feed
Puddle Dodgers Club
big_wasa
posted on 21/3/11 at 09:14 PM Reply With Quote
Where in the world are you mike ? never done a nissan but done many other ecu's
vtecmike
posted on 21/3/11 at 09:24 PM Reply With Quote
thanks guys for the various solutions ,im just going to have to get stuck into it!
by the way im lost in france!
thanks mike
RK
posted on 12/5/11 at 07:55 PM Reply With Quote
Did you find a solution to this? I have the same engine, but gave up on the ECU and went with an AEM. I didn't get it to work, and am getting rid of the car, I think.
vtecmike
posted on 12/5/11 at 08:11 PM Reply With Quote
havent done the wireing yet, should be starting it next month,
should be fun, ha !
i wil post up the results
thanks mike
