semi42
posted on 5/9/02 at 03:54 PM |
Cortina Pinto Engine and box Mountings
Pinto is from mk5/4 cortina. I Understand I may need to shotenthe sump and reposition the oil filler.Could Any locost Cortina builders give mesone
hints on enginemount brackets? Do I use the original engine brackets and rubber mounts? What mods are req'd on the gearbox mount.
Jon Ison
posted on 5/9/02 at 08:30 PM |
when i put the pinto in...(its long gone) i used the cortina gbx mount and the cortina engine mount rubbers,
i fitted the rubbers directly to chassis, then made a mount from top of rubbers to engine, gbx xmember was just bolted ti underdide of trans tunnel,
you will (unless you have arms like a monkey) need to extend the gear linkage.....
happy building....Jon.
