New Topic New Reply
Author: Subject: 4 point harness top fixings height?
Highcost builder
posted on 6/9/02 at 09:04 PM Reply With Quote
got a pair of 4 point belts can anyone tell me the height that i need to put the top mountings. thanks.
scutter
posted on 6/9/02 at 09:43 PM Reply With Quote
I'll try to explan,
according to the good book SVA, you need a referance block 136mm*53mm placed flat on the seat against the backrest(where you arse goes). the minimum height above this is 450mm for the upper mount.
Hope that helps Dan.
Highcost builder
posted on 6/9/02 at 10:07 PM Reply With Quote
thanks mate certainly does help what does 136 53 mean. is it 136 high or 53.
Thank-you
bob
posted on 6/9/02 at 10:30 PM Reply With Quote
53mm high and 136mm wide.
Highcost builder
posted on 6/9/02 at 10:43 PM Reply With Quote
excuse my ignorance but does the width refer to the two top fixing points
theconrodkid
posted on 7/9/02 at 05:57 AM Reply With Quote
nope that refers to the block,so if you come out from the seat back 136mm then go up 53mm add 450 to that point and that is the lowest point the mounts can be,wonder who dreamt up those dims?
Highcost builder
posted on 7/9/02 at 08:18 AM Reply With Quote
ah! got it thanks
gjn200
posted on 8/9/02 at 08:43 AM Reply With Quote
Will 4 points pass the sva then? Please say they will someone, as I thourght they had to be inertia ones and hence make a mess of the roll bar where they mount.
scutter
posted on 8/9/02 at 11:12 AM Reply With Quote
Four points are allowed, aslong as there E marked and have a release mechanism similar to a normal car seat belt( no race harnesses).
Dan.
gjn200
posted on 8/9/02 at 03:25 PM Reply With Quote
Excellent! Any recomendations anyone?
Highcost builder
posted on 10/9/02 at 07:36 PM Reply With Quote
yes mine have got the conventional car style release, got them from Hoopers of Hanham superb shop for all tuning parts.
david walker
posted on 11/9/02 at 08:37 PM Reply With Quote
As long as they are "E Marked", race harnesses are OK
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
gjn200
posted on 12/9/02 at 07:47 AM Reply With Quote
Cheers chaps, I see demon tweeks sell willans, omp and sparco specifically for w+c for about £50 each.
locost7-online.com
posted on 22/9/02 at 02:06 PM Reply With Quote
My Car has just passed with the top mounts on the chassis as in the book, I used high bach seats with headrests, run the belts through the headrestsupports and this passed.
The belts i used are TRS and have lap belt adjusters that you pull up, designed for west****d.
Take a look at my car www.locost7-online.com
bob
posted on 22/9/02 at 05:00 PM Reply With Quote
John
I like the seats,whats the story and how much?
locost7-online.com
posted on 23/9/02 at 07:29 AM Reply With Quote
Thew seats came from Stuart Taylor motorsport where i think he got them from is Richfield seating. They are not cheap, but i wanted to be comfy in the car....and 500miles on its lovely.
John
New Topic New Reply
