mikeb
posted on 5/12/11 at 11:46 AM |
Any one tried - Bike Fuel Pump Racers Edge
Seems a lot cheaper than a second hand zx6r one?
Any one tried one or like to comment if it will work etc?
Fuel Pump 2.5-5.5 PSI Ideal for Motorbike Carb systems | eBay
Mike
designer
posted on 5/12/11 at 11:58 AM |
It's a Facet pump 're-stickered', so should be OK.
Dusty
posted on 5/12/11 at 12:18 PM |
Supplied with in line external Filter (to be mounted between the tank and the pump inlet).
If that's a metal bullet filter like the facet ones that screws into the inlet side of the pump the best place for it is the bin. Fit a cheapo
plastic £1 inline filter instead. (It's a long and bitter story involving the sides of various roads, hard shoulders of motorways, rainy nights
and extreme frustration in identifying the intermittently blocked filter.)
mikeb
posted on 5/12/11 at 12:29 PM |
so a yes no on suitability of the pump.
Just wondered if its a better bet than a 12 year old second hand one?
mikeb
will check out the fuel filter if I get one.
i like the cheapy see through ones as at least you can tell if its blocked!
splitrivet
posted on 5/12/11 at 01:11 PM |
Well spotted I'll get myself one of those.
Bob
rsmith95uk
posted on 5/12/11 at 03:02 PM |
Definitely well spotted - just stuck in an order!
Paul Turner
posted on 9/12/11 at 06:20 PM |
With the quoted flow rate and pressure it will be OK up to about 130 bhp and no more. You will still need a regulator to use it with
Webers/Delorto's
ChrisL
posted on 2/1/12 at 04:51 PM |
Mike,
I have the same issue, re zx6r fuel pump. Currently have an 'always on' pump. Can you let me know what you think of it and if it is a
'low pressure on' type?
Chris
mikeb
posted on 3/1/12 at 04:50 PM |
I asked if it was an interupter type pump but they didn't know the answer.
I bought one anyway.
Its solid state and when plumbed in is always running, it doesn't seem to flood the float bowls and my engine runs with it but I've only
had it idling.
Mike
