Poorscousertommy
| posted on 12/1/12 at 11:09 PM |
What are these then and where do they go???
The only bit of my kit that I cant figure out.....
I'm sure they are pretty important!
Thanks as ever
matt_gsxr
| posted on 12/1/12 at 11:14 PM |
These are for hanging your rear brake calipers off.
They fit the rear non-disk-brake Sierra bearing carriers.
Poorscousertommy
| posted on 12/1/12 at 11:18 PM |
I'm confused... i did figure the PCD / hole pattern fit the carrier, but as there was no recess on the carrier and I have push in driveshafts, I
figured I had a drum setup.. Have I actually got a disc setup?? i.e. calipers??
I'll be mighty peed off if so as I've just shelled out waaaay over the odds for drums (I was kicking myself anyway at the price I
paid)!!
[Edited on 12/1/12 by Poorscousertommy]
austin man
| posted on 12/1/12 at 11:33 PM |
on the basic Indy the uprights for discs are different to the uprights for Drums
NigeEss
| posted on 13/1/12 at 12:00 AM |
paid)!!
Sorry Bud, they are brackets to fit discs to a drum braked upright, so yep, you spent £70 on a set of drums you don't need.
ashg
| posted on 13/1/12 at 07:31 AM |
if you use drums you dont use those plates. if you use discs then you use them.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mad-butcher
| posted on 13/1/12 at 08:20 AM |
use the drum brakes you bought, her indoors will be even more pissed off if you spend even more money on a set of calipers and discs, we have all made
mistakes when building these toys so you're certainly not alone
mine include
several 7.5" diffs
push in diff/shafts/reconned drums (shoes/cylinders/springs)
only to buy new rear uprights for discs (didn't know you could convert the drums to discs)
£150 odd quid on a smiths type speedo, only to discover the joys of an acewell, that comes complete with rev counter (at least I saved myself the cost
of buying one to match the speedo )
tony
Poorscousertommy
| posted on 13/1/12 at 09:05 AM |
Cheers Tony, glad its not just me
Think I will go for the drum setup for now, safe in the knowledge that a disc upgrade is a future winter project!
| posted on 13/1/12 at 12:29 PM |
Drums are also more than adequate for braking purposes too
As Tony says, I think everyone has the odd error in their purchasing plans. Mine included buying 3 sets of wheels, buying 6 metres of black vinyl
rather than 6 feet and buying enough coolant hose to plumb the car 4 times over
On the plus side, most parts are easily sold on again either here or ebay.
Poorscousertommy
| posted on 13/1/12 at 12:49 PM |
You havent seen the state of the drums I paid for!!
What on earth I was thinking I dont know... I'd just bought my powerlites and must have felt like splashing the cash!!
I knew as soon as I hit the button I had made a mistake.. Ho hum.. Anybody want to buy any drums?
big-vee-twin
| posted on 13/1/12 at 05:23 PM |
Here's how they fit.
[img]
  Rear Caliper Bracket
[/img]
[img]
  Rear Brakes
[/img]
http://www.triangleltd.com
