avagolen
posted on 31/1/12 at 06:36 PM |
Carb connections - Something Missing?
Good evening everyone,
Started to look at making a connection between throttle pedal and the ZX6 Carbs and
there is no simple way of locating the cable outer.
Is there something missing?
![](/galpreviews/Throttle_connection_carbs.jpg) ![carbs_throttle_connection](/gallery/Throttle_connection_carbs.jpg) carbs_throttle_connection
Any comments / pictures greatly received.
Thanks,
Len.
tony-devon
posted on 31/1/12 at 06:45 PM |
yes, from memory theres a plate that bolts onto the mounting above the choke plunger in the pic
heavy is good, heavy is reliable, and if it breaks, hit them with it
lewis
posted on 31/1/12 at 06:49 PM |
Yes a bracket missing,sits about 2"above the throttle linkage
I am a driving god!..........sort of
tony-devon
posted on 31/1/12 at 06:50 PM |
lewis
posted on 31/1/12 at 06:53 PM |
Another pic of the bracket from the side
avagolen
Thanks,
That explains why the top screw was not tight!
Any ideas where I can get one from?
Len.
lewis
posted on 31/1/12 at 07:10 PM |
Edit for double post,you could make a bracket,only needs one cable holder just copy the shape of the ones pictured,failing that eBay or bike breakers
online?
[Edited on 31/1/12 by lewis]
avagolen
posted on 31/1/12 at 07:31 PM |
Thanks Lewis,
Looks like my next job is a bit of intricate metal work
Len
stevec
posted on 31/1/12 at 07:51 PM |
I may have one you can have I will look in the garage for you, give me an hour
[Edited on 31/1/12 by stevec]
avagolen
posted on 31/1/12 at 08:05 PM |
Thanks Steve,
I will be patient.
Len.
stevec
posted on 31/1/12 at 08:13 PM |
I found these three, you are welcome to any of them you may be able to adapt one.
Steve.
![](http://locostbuilders.co.uk/upload/12bracket.jpg)
avagolen
posted on 31/1/12 at 08:30 PM |
Hi Steve,
U2U sent
Len.
[Edited on 31/1/12 by avagolen]
deezee
posted on 31/1/12 at 08:41 PM |
I've only just seen this thread, so sorry if its too late, but I have a rotten set of ZX6R that I use for spares. That very bracket is
available if you'd like?
avagolen
posted on 31/1/12 at 09:23 PM |
Hi Deezee,
Yes please. Save me some work.
U2U sent.
Len.
