TimC
posted on 3/2/12 at 08:53 PM |
More spatter in cold weather?
Evening all. Had a go at welding my pedal box in this evening. Went ok in the main but for some reason I was producing LOTS of spatter. Mig's
setting unchanged since the weekend when I had no issues. What's going on?
Ta,
Tim the welding novice.
MakeEverything
posted on 3/2/12 at 09:04 PM |
Gas ok, or gas less?
Kindest Regards,
Richard.
TimC
posted on 3/2/12 at 09:06 PM |
Gas ok as far as I could tell. I turned it up a bit but still not great.
posted on 3/2/12 at 09:17 PM |
Ambient temperature shouldn't make any difference to the weld, it's more likely something you are doing different without realising like
changing the gun angle or pulling instead of pushing.
Tatey
posted on 3/2/12 at 09:18 PM |
Your not using any magnets to hold the pedal box together are you? I recently had welding issues with brake line brackets, I checked everything,
turned out it was the welding magnet behind the bracket that was screwing everything up.
T66
posted on 3/2/12 at 09:23 PM |
Gas left in your bottle ? regulator turned down, draughty part of the garage ?
Unclean job, my Lada had underseal like earwax which caused huge splatters.
fesycresy
posted on 3/2/12 at 09:30 PM |
Moisture in the atmosphere can affect spatter. Try flashing a turbo torch over the steel first and then see if you get the problem.
The pedal box isn't oily is it?
Have you made sure your shroud is clear, the majority of spatter problems come from a poor shield.
Also voltage / current settings affect it, but you haven't altered these and I assume the steels are the same thickness?
What spatter spray are you using, I've got the vegetable oil based one at the moment and I think it's not as good.
TimC
posted on 3/2/12 at 09:43 PM |
Hmm...
No magnets, cleaned and dried before hand, gas seems okay. Not using anti-spatter and not really had issues up to now.
I'll try again tomorrow.
Wadders
posted on 3/2/12 at 10:51 PM |
Are you using argoshield or co2, if its co2 your bottle could be freezing up.
Al.
arrow-engineering
posted on 4/2/12 at 12:25 AM |
ive been having this when its cold, the regulator ices up and it doesnt flow right, ive been pointing a little heater at the mig while working. as
soon as the bottle and reg warm up welding goes back to normal.
fullpint
posted on 4/2/12 at 07:56 AM |
I've heard of this before. Tim; It was a cold one yesterday. I had to warm up the fan on my oven (and control box on the extraction) with a
blower before any thing was going to work.
Wait till the afternoon mate. Pop a little heater in the garage an hour or so before you fire up the TIG unit
I've over 28 years in dealing with magnesium wheels. Refurbishment and can powder coat most metal parts. Visit my web site if you wish..
www.tpcs-magnesium-refurbs.co.uk
mad4x4
posted on 4/2/12 at 09:58 AM |
Ambient temperature will change the gas volume and flow as the pressure in the cylinder will drop as temp goes down (not that much) but may require
you to turn up the flow a bit
Scot's do it better in Kilts.
DIY Si
posted on 4/2/12 at 10:14 AM |
I'd go with this. I had major issues with my welder the other day for exactly the same reason: the reg had partly frozen up. It would flow ok
for a couple of seconds and then stop. So the welds start nicely and then just dissolve to splatter as the gas stops. Easily solved as said with a
little fan heater.
Oh, and that's with Argon/CO2 mix on a 6 month old reg on a Migatronic should it make nay difference.
Sun Tzu, The Art of War
omega 24 v6
posted on 4/2/12 at 11:32 AM |
Damp atmosphere over the week causing your welding wire to rust??
benchmark51
posted on 28/10/12 at 03:38 PM |
I have recently got a new bottle from Hobbyweld, it is argon/co2 mix. The difference from using just co2 is brilliant.
I also find cleanliness of the metal, front and rear, is important. Replacing the contact tip regularly and minimse draughts all help.
