tony-devon
posted on 8/2/12 at 02:50 PM |
alternative rear hub carriers??
ok, as sierra parts are like rocking horse poo to get hold of, Im looking for alternatives
what cars have rear hubs that bolt up like a sierra has?
I can get BMW diffs etc cheap enough and prepared to mix and match no problems, but looking for an easy option for the outboard mounting.
Im planning on using probably a BMW diff as I can get the close to the 3:1 ratio quite easily that my bike engine wants, but the quick look Ive had
appears to show that the rear arm and hub etc look like one peiece?
heavy is good, heavy is reliable, and if it breaks, hit them with it
posted on 8/2/12 at 05:02 PM |
You can buy alloy Sierra hub carriers at quite reasonable prices, there was a recent thread that listed some suppliers.
http://www.locostbuilders.co.uk/viewthread.php?tid=165392
rdodger
posted on 8/2/12 at 05:14 PM |
Did you want Sierra drum or disc bearing carriers?
I have some drum ones with the drive flange machined down to suite the RD/Wilwood disc handbrake caliper if you want them?
