Kartdad
posted on 4/4/12 at 10:19 AM |
Wheel Spacers
Dear Builders
I am planning to add a set of Caterham wheels that I have bought (lush) to a Escort axel and I need to add about 1" of spacing both sides as the
wheels have a deeper offset than I had planned
Does any one see an issue with this spacing?
also I need some ford wheel nuts for building not finnishing any spares in boxes out there ?
many thanks
KD
Daddylonglegs
posted on 4/4/12 at 11:05 AM |
I hope there aren't any issues mate, I've got 25mm spacers on my alloys to clear the trailing arms
I think it's only when you're going much thicker that the concentric ones are needed?
Might be able to help with the wheel nuts chap, I'll have to have a check tonight. I'm sure I've got some kciking about in there you
can have for postage
[Edited on 4/4/12 by Daddylonglegs]
ashg
posted on 4/4/12 at 02:01 PM |
at 25mm you should be using concentric ones. eibach make nice ones that are safe they cost about £110 for a pair each one 25mm thick with all the
required fixings.
when it comes to wheel spacers its best to buy the pucker items for the job as at the end of the day they are the things keeping the wheels on the car
and you plus others alive.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
