randombloke
posted on 9/4/12 at 02:48 PM |
Best place to purchase Mild Steel
Hello everyone
I want to get peoples opinion on the best places to purchase mild steel box section?
jacko
posted on 9/4/12 at 03:14 PM |
I would say look in your yellow pages for the nearest steel stockist + have a ring round
Jacko
Simon
I got mine from IS&G but have also bought quite a lot of steel from Parkers - not sure if either of these outfits are near enough to you.
Have a look on yell.com or google if above no good
Simon
mark chandler
posted on 9/4/12 at 03:49 PM |
IS&G for me as well. always try and argue price down with whoever
iank
posted on 9/4/12 at 04:00 PM |
If you fancy a go at mail order for convenience...
http://www.metals4u.co.uk/detail.asp?cat_id=49&prd_id=2382
But always order in full (6m) lengths wherever you go as cutting charges are always ridiculous. Cut it up yourself in the car park with a hacksaw to
get it on the roof rack if you must.
Anonymous
Brian R
posted on 9/4/12 at 05:44 PM |
Both Parkers and Brundles deliver to your area.
http://www.parkersteel.co.uk/
http://www.fhbrundle.co.uk/groups/30__Steel_Sections
Slimy38
posted on 9/4/12 at 06:12 PM |
wow, 3 metres for £12 and 6 metres for £16!!! I see what you mean about ordering them in full lengths! Although you'd have thought the delivery
charges for 3 metres would be less?
Is that a good price, 6 metres for £16? Assuming you buy enough to get free delivery?
randombloke
posted on 9/4/12 at 06:32 PM |
Thanks for the quick response everyone, I will check out your suggestions.
One questions on the steel itself, I have bought 25mm x 25mm x 2mm box section in the past that had a 4 or 5mm radius on the corner curves but I have
seen a lot of build diaries on here where the box section corners are much squarer, more like 1 or 2mm radius. Is this just down to manufacture,
smaller wall thickness or any other reason? The reason I ask is aesthetically I think it looks better, I'm just about to start building my
chassis and would prefer to use the squarer type.
Regards,
Philip
SteveMX5
posted on 9/4/12 at 08:56 PM |
You want 25mm erw this has the nice sharp corners. I have used 1.6mm wall thickness which is plenty strong enough but 2mm wall is possibly easier to
weld and may be stronger but obviously weighs more. I brought all of my steel from Barratt steel, they have an online quotation system. I think I paid
£120 ish for all my box section.
iank
posted on 9/4/12 at 10:54 PM |
It's not a terrible price, but the prices go up and down all the time so a decent stockholder will generally be able to beat it - if they can be
bothered to deal with a private sale.
Just noticed that Barratt have a depot 5miles away from my house that I didn't know about, will have to get a quote from them when the time
comes to start building again.
Anonymous
nickharding
posted on 9/4/12 at 11:16 PM |
How much would you recommend ordering if your doing the "book" chassis including the amendments?
About to make an order shortly for my new build.
Cheers.
iank
posted on 10/4/12 at 09:01 AM |
Cheers.
If book means the live axle escort based Ron Champion version then use the corrected McSorley plans here
http://www.sevenesque.com/plans/
There is a BOM file in excel which has an optimised cut-list. It's in inches and assumes 10ft lengths which is presumably a US standard
length.
It says 11 lengths and a total of 1210 inches required. So a touch over 30m. I'd be buying 6-7 6m lengths as I'd be bound to screw up
one or two bits
Remember all the bits of 3/4" and round tube when you make an order.
If it's haynes then it's a bit bigger, there must be cut lists somewhere on the haynes forum, or ashg will know.
Anonymous
nickharding
posted on 10/4/12 at 09:59 AM |
Hi mate,
Its the Haynes roadster chassis.
Be nice to order it all in one go!
Will drop AshG a message now.
Cheers!
thefreak
posted on 10/4/12 at 02:35 PM |
I just go down to the local fabricators and pick it up from them.
Last lot was 1000x1000x1.6mm aluminium sheet and a couple of 1.5m lengths of 40x25mm box. Total price... £10 cash
Simon
posted on 11/4/12 at 09:07 PM |
Fwiw, I didn't bother with 3/4" for the trans tunnel, did the whole lot from 1". I think the weight penalty is insignificant.
Simon
randombloke
posted on 12/4/12 at 08:08 AM |
Hello Everyone, thanks for your comments on this post.
I decided to by my steel from Barratt Steel as they offered a really good price. The only problem they didn't have seamless tube so I will need
to find this from another supplier.
Thanks,
Philip
posted on 12/4/12 at 08:28 AM |
Spotted these guys the other day local to me in Winchester. No experience of them, but might be worth a try.
http://www.bmsteel.co.uk/winchester
Slimy38
posted on 13/4/12 at 05:06 PM |
I had this in mind when you first posted, but it's taken me until now to find it!!
http://www.mig-welding.co.uk/metal-suppliers.htm
