T66
| posted on 18/4/12 at 04:19 PM |
Gearchange/Handbrake Console Fab
I have started making up a console to house the gearstick & handbrake lever. I am after advice on gearstick lengths suitable for the Blackbird
engine.
Its a nice straight ish run to the gear shaft, so I will probably be using a threaded rod..
What amount of forward/rearward throw will the stick need please ?
T66
| posted on 18/4/12 at 08:00 PM |
Is this in the wrong section ?
40inches
| posted on 18/4/12 at 08:53 PM |
I think this is a how long is a piece of string type thread
The lever above the pivot, on mine, is about 4 times longer than the lower, I drilled around 4 holes in the lower bit, extended the gear lever on the
box, and drilled a series of holes in that too. Then I played around with the pivot points until it felt ok, I think I have around 50mm lever throw in
each direction.
  Reverse panel
  Shiny Gearlever
T66
| posted on 18/4/12 at 09:00 PM |
Thats exactly what I was after - A ball park bit of a clue. At least I have a startline for the dimensions which helps
cheers
