New Topic New Reply
Author: Subject: powder coated shiny fury suspension
FuryRebuild
posted on 17/5/12 at 07:50 PM Reply With Quote
So, as you may know, I'm rebuilding my fury, and i've just sent off all the suspension to be powder-coated when it was starting to rust through.
It was a job that was all about preparation - having to work out where the handbrake cables, etc. needed to run and welding in brackets to provide smooth run-paths rather than cable-tieing brackets to components, eventually rubbing off the coating.
So, I've gone from this:
which is trying the fit and run. Believe me, it was a ball-ache to go and put this lot back on the car when I thought I was finished, but I also realised it wasn't worth doing a half arsed job.
To this, on the bench:
To all these back from the coaters:
www.furyrebuild.co.uk
RichardK
posted on 18/5/12 at 10:56 AM Reply With Quote
Mmmmmmm....Shiny
Me like
Rich
Gallery updated 11/01/2011
FuryRebuild
posted on 18/5/12 at 10:58 AM Reply With Quote
I now need to get in there and recut the threads, and take the powder coat out the the tapered holes. But yes, the coaters put it on nice and thick
iank
posted on 18/5/12 at 11:14 AM Reply With Quote
Shame they didn't mask off the threads/tapers though.
Hope they blasted it first.
Anonymous
FuryRebuild
posted on 18/5/12 at 11:30 AM Reply With Quote
Hi Ian
Most threads and tapers were stuffed with paper wedged into a solid mass, or had a bolt through (not very clear in the photo).
Inevitably there's some bleed through and that will need a little tidying up.
For important things like the wheel-bearing surface on the hub, I've masked it with paper and then tape. If you only mask with tape the heat of the coating process melts the adhesive and it's a pig to get clean.
I'm fairly happy with the results
MK9R
posted on 18/5/12 at 09:00 PM Reply With Quote
i'm afraid to say that powder coating them ensures your will need to modify them I got my live axle links back and fitted them to my newly built axle, only to find the springs caiyght the casing, so had to cut off the damper pickups and weld them on 20mm further away, grrrrr!!!!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
adithorp
posted on 18/5/12 at 09:17 PM Reply With Quote
Is that a conversion from live axle to indy? Just that I've not seen some of those brackets before.
http://jpsc.org.uk/forum/
FuryRebuild
posted on 18/5/12 at 09:20 PM Reply With Quote
Nah. Mines an original 1st gen IRS, with the golf struts and so on. When converting to cosworth disks I ended up with new cables to run. So, I added brackets.
New Topic New Reply
