New Topic New Reply
Author: Subject: Paint for ali
Chris_R
posted on 11/9/04 at 08:27 PM Reply With Quote
Paint for ali
I'm gonna paint my ali floor separately from my chassis. Anyone got any suggestions for the best primer/paint combo for aluminium?
Chris.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
stephen_gusterson
posted on 11/9/04 at 10:24 PM Reply With Quote
mark allanson is the main to ask. you need an etch primer methinks to stop the paint flaking off.....
do you need to pain alu? underside wont show, and you could put some car carpet or rubber sheeting inside
atb
steve
Chris_R
posted on 11/9/04 at 11:35 PM Reply With Quote
Well, it's not gonna corrode, but I like things to be tidy. Besides, it's a reclaimed sign from an industrial estate and there's writing all over one side. Gonna sand it, but don't want the scratches.
Etch primer sounds good, but can you brush it on?
[Edited on 11/9/04 by Chris_R]
Mix
posted on 12/9/04 at 07:50 AM Reply With Quote
Yes you can brush etch primer, it gives a surprisingly good finnish 'off the brush'. I strongly recommend that you put some form of protective finish on the underside of your floor especially around any metal to metal joints. Aluminium will corode like mad especially if it comes into contact with road salt. Bonnets are easy to keep clean, not so the underside of your car.
Mick
Mark Allanson
posted on 12/9/04 at 07:08 PM Reply With Quote
The safest way of applying 2K chromate etch is with a roller, it is more even, quicker (less time at risk). Please remember the stuff is lethal, best done outside on a breezy day.
Standard 2K etch is not as dangerous, but still needs care, it is not quite as good a chromate, but better that any of the 1K stuff available.
Chris_R
posted on 12/9/04 at 07:19 PM Reply With Quote
Mark, thanks. don't suppose you'd have a rough idea of price?
Mark Allanson
posted on 12/9/04 at 07:57 PM Reply With Quote
About £22 for a litre of std etch with accellerator - don't get chromate, even if they would sell it to you, you would probably contract cancer by using it. I used to use a full rebreather suit when I used it 12 yearsago
Chris_R
posted on 12/9/04 at 08:05 PM Reply With Quote
£22 or slow painful death. Think I'll go for standard.
Mark Allanson
posted on 12/9/04 at 08:30 PM Reply With Quote
We were warned that death could be almost instant in some cases, without warning, paralysis of the nerves that make you breathe, the same ones that tell you that you cannot breathe, first thing you know is that the lights go out
Chris_R
posted on 12/9/04 at 08:45 PM Reply With Quote
Think I'd rather go for bog standard. Thanks for the warning.
Mark Allanson
posted on 12/9/04 at 08:56 PM Reply With Quote
I have the equipment to use chromate, but I am going to use std 2K etch - I want to enjoy driving the car as well as building it
Chris_R
posted on 12/9/04 at 09:03 PM Reply With Quote
Good choice. I've got the facilities to spray, but unfortunatley nowhere to do it. Can't wait for that lotto win and the workshop that follows.
DaveFJ
posted on 15/9/04 at 12:46 PM Reply With Quote
We used Alocrom 1200 on aircraft - great stuff!!
2 part mix that after a couple of hours started to give off cyanide gas (or som closely related derivative) unless disposed of properly
And yes - being squaddies we didn't use anything more advanced for protection than a pair of plastic gloves
Dave
limy john
posted on 22/9/04 at 02:49 AM Reply With Quote
primer
i know alot about this, i've even got a piece of paper that says so,
strip the paint off with stripper, if you want the best finish, take it to be anodised, and then leave it alone as it will not corrode, you can even have a colour.
alternativly clear anodise and then paint with any etch primer, rollered on, you won't drop dead just do it in a ventilated area, use a mini roller.
you only get a problem if it is sprayed and becomes airbourn as particals.
do not flat after application, do this just before painting.
remember, any paint under the car will chip eventually
posted on 22/9/04 at 07:26 AM Reply With Quote
Isn't that the solvent? MEK if I remember correctly - I was given a small pot by a painter friend, who said "it's not really inflammable - explosive is a better description!" So volatile that if you leave the lid off the jar for an hour it'll evaporate away - with all the risks you describe.
MEK = Methyl Ethyl Ketone (I think)
P.S. Your description sounds like the risk sheet for argon welding gas - if you work in an enclosed space the argon replaces the breathable air, but it doesn't trigger the "OI! you are suffocating" reflex and you fall over without warning.
[Edited on 22/9/04 by David Jenkins]
DaveFJ
posted on 22/9/04 at 08:22 AM Reply With Quote
MEK = fantastic stuff - just NASTY
years ago we used to wash our hands with it at the end of the day!!! then we were told exactly why it was a bad idea.......
get some !
here
well worth it!
Dave
NS Dev
posted on 23/9/04 at 12:18 PM Reply With Quote
crikey, now I'm all worried!
Mark A - if I go to my usual paint supplier and get "activated cellulose etch primer" then that's not so bad is it? That's what I usually use, yellowish tan sort of colour stuff, that comes with a bottle of special "activated" thinners .
I always use Cellulose paint cos of the dangers of 2 pack stuff.
[Edited on 23/9/04 by NS Dev]
New Topic New Reply
