FuryRebuild
posted on 23/10/12 at 09:10 AM |
Fury Footwell Finally Finished - causes alliteration to break out across the land, and pics
So, I've finally finished my footwell, massively modified to take my equally modified OBP pedal box.
Here are some pictures for you:
This one is more or less the money shot - it's the transmission tunnel recess, designed to give enough clearance for the wide duratec
bellhousing at the same time as accommodating the obp pedal box. You can also see the little box I had to fabricate to allow the throttle pedal to
have full travel. I did test it against my jenveys and sure enough it seemed to want to go all the way - I'd sooner have the full travel even if
I later didn't need it rather than the other way around.
Here's the pedal box, it's a totally snug fit in there now. Each pedal has about 5mm clearance with the side as it goes it's full
travel.
Here's the full frontal. There's been a little warping when welding, but the pedal-box goes in straight and bolts up true.
Finally, the vertigo inducing top down shot
www.furyrebuild.co.uk
Davey D
posted on 23/10/12 at 09:17 AM |
Looks good, but surely you will kick the top of the footwell when pressing the pedals, as there doesnt look to be much space above them?
FuryRebuild
posted on 23/10/12 at 09:18 AM |
Hi Davey
I've tested that, and it's fine. There's a lot of pedal, and my legs are very much out flat in the car, with my heels resting on the
lower cross-member.
The height is the same as the original footwell.
TimC
posted on 23/10/12 at 10:22 AM |
It's lovely work, but how much does that lot weigh?
FuryRebuild
posted on 23/10/12 at 10:25 AM |
Not sure - may have cost me half a kilo over the original footwell, which was a similar size. it's still just 1.5mm mild steel.
The new pedal box is the same weight as the original, which I couldn't use (moving over to hydraulic clutch).
DH2
posted on 23/10/12 at 11:07 AM |
Nicely done.
Looks like alot of faffination to fit a pedal box which a number of my friends have put in the bin for being too flimsy... hope your mileage
varies.
DH2
FuryRebuild
posted on 23/10/12 at 11:09 AM |
We shall see. It's the race box. Seems like a reasonable design and I've been sure to give it a strong bulkhead to mount to. Most of the
braking force should go to the bulkhead (footwell front).
scudderfish
posted on 17/11/12 at 02:20 PM |
I saw this on the underside of the wing of the SR-71 Blackbird at Duxford and immediately thought of you
If it's good enough for Mach 3.2, it's good enough for a Fury.
FuryRebuild
posted on 17/11/12 at 02:30 PM |
Scudderfish
You properly had me laughing there, but it does go to support the premise that 1" spacing is the way ahead for structural work.
And thanks lots
striker-4age
posted on 17/11/12 at 03:33 PM |
Looking good m8 !!!! Love ur little user picture what engine u using ??
