Macca
posted on 24/9/02 at 07:16 PM |
What to do with those 4"
If I build a book chassis but with an irs what do I do about the difference in track.
Do I shorten the drive shafts to match book front.
If I don't shorten the drive shafts do I lengthen the wish bones.
If I dont lengthen the wish bones to I move the wish bone mounts.
Or do I stick an axle on it as its just as good/easier.
Cheers Col.
Simon
posted on 24/9/02 at 07:28 PM |
Col
Luego have IRS on their "book chassis". They shorten the driveshafts from what I can recall. I have been very impressed with what I've had from
them, and with their service. Could be worth a call - what save a lot of hassle measuring etc, as they've already done it!!!
I, having just built my "book + 4 inches wider" chassis using Sierra diff / shafts / homemade wishbones, will be buying a chassis next time.
So far (and there's a long way to go) it's been fun, but next time (if) I'd take the assembly job, rather than complete construction
Simon
Marcus
posted on 24/9/02 at 07:42 PM |
Keep the drive shafts the same length and buy wide wings from MK etc. The difference in track makes next to no difference to the handling.
Marcus
Roeland Uitslager
posted on 25/9/02 at 10:07 AM |
Col,
In the book "How to build your own Tiger Avon..." they use the original driveshafts. A wider track doesn't affect the handling.
If you want to shorten the shafts it's not an easy task.
Roeland
Mark Allanson
posted on 25/9/02 at 09:28 PM |
I am relieved that the wider track at the rear will not affect the handling, but a thought came to me about how this will affect the lighting
regulations, will I have to have the headlamps over the top of the front wheels to satisfy the SVA man? Best read my SVA manual!, but it is a bit
heavy going.
Mark
Macca
posted on 25/9/02 at 10:35 PM |
May be I didn't explain very well, if I go for the wider track where does the extra width come from?
1 Longer wishbones
2 different mounting points
Col.
stephen_gusterson
posted on 25/9/02 at 10:50 PM |
longer wishbones.
seriously consider the time and hassle of doing irs.
i would use a live axle if i was starting again, save lotsa time.
atb
steve
