New Topic New Reply
Author: Subject: Mx5 based chassis plans
mastarforth
posted on 5/4/13 at 03:43 PM Reply With Quote
Hi guys
I am sure this has been done to death, but can someone point me in he direction of plans for a roadster based on mx5
Looking for new project after completing my mev
Thanks in advance
Andrew
Slimy38
posted on 5/4/13 at 04:03 PM Reply With Quote
http://gillhamonline.co.uk/shop/page/12?sessid=UfeDnJA7Xk0T06jeLZSVQUWpEABcBCslS1LcapKW6IU7PkkgBuGeUHzCZuT1rHmc&shop_param=
Talon Motorsport
posted on 5/4/13 at 04:10 PM Reply With Quote
You have a few options here with regards to mx5 Roadster plans.
Saturn plans I have a copy but a few measurements are missing from the wishbones...
Vodou plans are incomplete at the rear with regards the rear coilovers.....
or
Build a standard roadster chassis as per the book and replace the mx5 ali diff cover with the arms for a fabricated diff cover and make custom rear wishbones.
the49ers
posted on 8/4/13 at 09:20 PM Reply With Quote
Hi Andrew
This is my first ever post!!!
I started the Haynes Chris Gibbs this christmas and am using the MX5. I have used the saturn plans and yes some rear wishbone measurements are not there.
I am currently making the jigs so shouldn't be toooooo long before I can trail fit the rear wishbones. I have made the bottom to the book (as the Saturn plans say) and need to work out the tops.
I am going for 90' for the hub then use the adjusters for camber. A good enough starting point I think.
This is my first build but have run stockcars (got too old for these) for a number of years and I am an engineer
Can keep you updated if needed, or if anyone has any measurements that could help?
many thanks
Camber Dave
posted on 8/4/13 at 10:04 PM Reply With Quote
MX 5 Roadster
We are building a Roadster to the Chris Gibbs book so it will take standard Bodywork.
It will be designing to take the (MX 5) diff, gearbox and Engine.
We will also be designing the Suspension from first principles to take the Mazda wheels, hubs, uprights and brakes
The build is only up to page 37! so far but the drawings are further advanced.
Once the build is proved I am willing to provide copies of the changes we have made.
U2U me and I will start a mailing list.
Dave
rick1962uk
posted on 26/4/13 at 08:47 PM Reply With Quote
hi im just about to order the steel what do you recon on the best size all its for is track days so light weight 1" 16 swg or 18swg i want it light but safe will be one of 2 engines mx5 omega 2.2 or bike engine
many thanks rick
Simon
posted on 28/4/13 at 08:34 AM Reply With Quote
Rear wishbone measurements missing not a prob. All you need is a braced triangular ish shape to get your wheels in the right place and to allow for a slight amount of adjustment. That's how I did mine - on the road 6 years ago You know how a ruler works so measure them up yourself!
Simon
[Edited on 28/4/13 by Simon]
New Topic New Reply
