New Topic New Reply
Author: Subject: Where Can I get a Rollbar Extension Hoop?
Litemoth
posted on 12/4/13 at 02:09 PM Reply With Quote
I'm a lanky so and so...so need to add something to my rollbar to prevent nut-scrape should I go over.
Does anyone know of, where I can buy, have or can make me, a little extension loop (preferably the 90 degree version)?
The notching and welding isn't a problem.
I can bend and fabricate a bit of scaffolding tube but I hoped someone would know where I could get the real thing.
[img] Description
[/img]
rb968
posted on 12/4/13 at 02:21 PM Reply With Quote
Give Tom a ring at http://www.tube-bender.co.uk/
I used him for my rollcage.
Rich
twybrow
posted on 12/4/13 at 02:27 PM Reply With Quote
I too am a lanky bugger, and would be interested to hear how you get on. Is there any chance you can let me know (I can weld, but I can't notch!).
Slimy38
posted on 12/4/13 at 02:41 PM Reply With Quote
I can see from your avatar picture that your head would be on the floor before the roll bar hit, so definitely a good call there. Although I have to admit the whole thread makes me think whether I should take this sort of thing into account at build time.
Litemoth
posted on 12/4/13 at 02:50 PM Reply With Quote
Thanks Rich. Tom the Bender looks just the job!
I gave him a ring but looks like he's clocked off for the day. Some of the standard bends he does will do the job well but I'll see if he can do the odd-legged 90 degree bend I have in the sketch above.
Top lead
Litemoth
posted on 12/4/13 at 02:59 PM Reply With Quote
Ideally you'd make the roll-over bar/s high enough to clear your head in the first place but over a certain height it all starts to look a bit odd. I think you're supposed to have 75mm head clearance too (FIA?) - to allow for the slop and give in your harness and carcass as you flail around during a barrel roll (God forbid). Is it aesthetics or safety that is more important?....exactly, aesthetics..
twybrow
posted on 12/4/13 at 03:06 PM Reply With Quote
I'll just leave my helmet off, then I should be fine!
It is something I need to sort - my seat is on runners, which I could remove and gain another 30mm or so, but even still, a bit of extra height is no bad thing.
welderman
posted on 12/4/13 at 03:16 PM Reply With Quote
Got some mild steel ones at work. Not cds. Can't remember sizes can measure Monday
Thank's, Joe
I don't stalk people
clanger
posted on 13/4/13 at 06:43 AM Reply With Quote
this any good to you???
got a two bent the same time as this one. CDS. and for a Striker no less.
u2u me if you're intersted. In neath so not a million miles away....
minitici
posted on 13/4/13 at 06:59 AM Reply With Quote
Although you see a few cars with roll hoop extensions, they are not legal for MSA competitions where a ROPS is mandatory.
You could probably get away with the extension if you were running the car in a 'road going' category where ROPS is only advised.
Litemoth
posted on 13/4/13 at 01:44 PM Reply With Quote
Thanks for the heads-up but I won't (probably won't) be competing in it - I just wanted to convert the white-elephant of a roll over bar into something that may protect me a bit, should I run out of talent.
New Topic New Reply
