New Topic New Reply
Author: Subject: Striker Chassis - Mounting of Handbrake Retainer Tubes
Litemoth
posted on 13/4/13 at 02:36 PM Reply With Quote
Something that's niggled me for a while is the way the handbrake retainer tubes welded to the chassis direct the cable right into the diff mounting lug.
I assume this is the case with all the factory fabrications of the Sylva/Raw chassis?
Whilst the diff was off and some other work was going on, I decided to pack the tubes across to reduce the kink this caused and reduce the friction on the cable. The cable coming from the handbrake had failed previously and this had to be a big contributing factor.
[img] Description
[/img]
New tubey packing bit made up:
[img] Description
[/img]
And welded back on:
[img] Description
[/img]
I had to remove the diff lug to gain access with the angry grinder then weld back on.
[Edited on 13/4/13 by Litemoth]
clanger
posted on 13/4/13 at 05:01 PM Reply With Quote
i went the whole hog and put it all in the tunnel, lever an all, where it should be.......
[Edited on 13/4/13 by clanger]
TimC
posted on 13/4/13 at 08:26 PM Reply With Quote
I was looking at my options for the handbrake today (non-Striker) - it's not looking easy at all.
daniel mason
posted on 13/4/13 at 08:35 PM Reply With Quote
hydraulic is allowed now i think!
New Topic New Reply
