New Topic New Reply
Author: Subject: space saver for trike everyday?
v8kid
posted on 16/7/13 at 10:56 AM Reply With Quote
Its quite difficult to get sticky skinny square treaded tyres for trikes and other light vehicles so why not use a space saver tyre?
They are governed for by the same set of regulations that apply to everyday tyres so as long as the load rating and the speed ratings are suitable they are OK.
I checked on the Camskill site for specifications and the highest speed rated "skinny" I could find was a Pirelli who do a 135/80/14 tyre that has a load rating of 80 i.e. 450kg so thats OK but the speed rating is P i.e. 94mph. I guess that is OK for most trikes or light vehicles but some may have ambitions to go faster.
Anyone know of a higher speed rated skinny tyre?
Space savers have a disadvantage in that they only come with 3mm tread new so the life is short but they are made with a soft sticky compound to give similar roadholding to their larger bretheren so the traction should be a lot better.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
posted on 16/7/13 at 11:01 AM Reply With Quote
Interesting line of thought!
How do they stack up on price?
What tyres does the Morgan 3 wheeler use - they must be pretty well rated given the vehicle's capability?
Might be some useful info here - http://www.longstonetyres.co.uk/page/morgan-3-wheeler
[Edited on 16/7/13 by nick205]
Mr Whippy
posted on 16/7/13 at 11:05 AM Reply With Quote
2vc tyres are quite skinny too
v8kid
posted on 16/7/13 at 01:40 PM Reply With Quote
Thanks for the suggestions but I'm really looking for tyres with modern construction and rubber - hence the spacesavers!
I'm wondering how the speed rating is calculated - if the loading is say 20% of the rated loading would the safe speed rating be increaced or is it a cetrifugal force thing?
Cheers!
Bluemoon
posted on 16/7/13 at 01:45 PM Reply With Quote
^^ Not sure but as they specify a load and speed rating for tires I doubt you can de-rate one for the other...
posted on 16/7/13 at 02:19 PM Reply With Quote
Space savers are limited to 50mph
Maximum speed of a tyre can be limited by quite a few factors not just load/pressure/heat, one of the factors is centrifugal force. Going back yonks I once saw a film of a big name tyre on a test rig shedding tread blocks purely due to centrifugal load and it was only equivalent to about 135 mph.
[Edited on 16/7/13 by britishtrident]
Mr Whippy
posted on 16/7/13 at 02:34 PM Reply With Quote
Cheers!
I don't think it works like that at all tbh, I also think the 50mph limit on space savers is more to do with driving around with two different tyre sizes. Maybe the rating on the tyre is higher?
New Topic New Reply
