New Topic New Reply
Author: Subject: Wishbone tube?
Slimy38
posted on 27/7/13 at 03:18 PM Reply With Quote
Wishbone tube?
I've been looking for the 33.7 x 2.6 tube for the wishbones, the closest I've found is 33.7 x 2.5. Is it reasonable to assume that 0.1mm absence should be ok, considering it's going to have a poly bush inside it?
Mr Whippy
posted on 27/7/13 at 04:12 PM Reply With Quote
I highly doubt much in the way of calculations were done to get the original size, 0.1mm is irrelevant
mark chandler
posted on 27/7/13 at 07:52 PM Reply With Quote
I used landrover series III and 90/110/defender steering arms for my lower bones, most 4x4 dealers simply replace the whole item as the Track rod ends are rusted solid so these are just scrap.
Regards Mark
jossey
posted on 28/7/13 at 08:21 AM Reply With Quote
Did you measure the other one with paint on it?
David Johnson
Slimy38
posted on 28/7/13 at 08:38 AM Reply With Quote
Mmm, good point...
Talon Motorsport
posted on 28/7/13 at 09:35 AM Reply With Quote
Are you talking about these very hard to find bush tubes that can be supplied by any body making Haynes Roadster wishbones, I've only been making parts for the past 5 years so I guess I'm a fairly well kept secret as an unknown supplier....
Slimy38
posted on 28/7/13 at 10:16 AM Reply With Quote
Yep, I am aware of those parts, but I'm also aware of the price of buying them individually compared to just buying a length of tube...
And I'm also still waiting for my MX5 diff cover by the way...
[Edited on 28/7/13 by Slimy38]
Talon Motorsport
posted on 29/7/13 at 08:10 AM Reply With Quote
How many bush tubes do you want? I'll throw them in with the diff cover...
Slimy38
posted on 29/7/13 at 08:19 AM Reply With Quote
I'm after a full set of 22, but I'm sure that will leave you out of pocket. I've seen the message on Ebay by the way, the mockup is fine for me. If it does the job then I'm happy.
New Topic New Reply
