jps
posted on 20/8/13 at 08:28 AM |
The 'permanently marked on the chassis VIN' - pics please!
As above really - i'd like to see how others have done it - just to see if what I have in mind is in line with that!
loggyboy
posted on 20/8/13 at 08:41 AM |
Mines engraved, by Raw, who stupidly put a 'I' in it, which I have since changed to a 1.
Mistral Motorsport
monkeyarms
posted on 20/8/13 at 11:46 AM |
I stamped mine. At IVA the tester said stamped is fine but their prefered method to see was a thin strip of metal with number stamped on, then fully
welded onto chassis, weld all around it.
jps
posted on 20/8/13 at 11:58 AM |
I've got two strips of 3m steel - roughly 15cm long - with the VIN etched into it 1mm deep - with letters about 12mm tall.
I'm thinking of welding one between the two cross members which will support the seat runners - and the other across the bottom chassis rails in
the engine bay - at the bulkhead end of the bay. So both of them would be fully welded, but at either end of the strip - rather than all the way
around.
adithorp
posted on 20/8/13 at 12:10 PM |
Stanping direct into the chassis is fine but beware of denting the tube. Engraving avoids that risk as does stamping a separate strip and welding
that on.
After a few recent IVA fails it appears that if the VIN is on a welded on plate, it must now be seam welded all the way around; Welding just the ends
(as mine was for SVA) won't pass anymore.
It must also be on a main structural part of the chassis; Having it as a tag on the side of one member or across between 2 isn't acceptable.
http://jpsc.org.uk/forum/
big_wasa
posted on 20/8/13 at 12:20 PM |
I did a stamped strip and seam welded to the chassis.
jps
posted on 20/8/13 at 12:50 PM |
Is it possible to ring up at IVA test centre and get feedback from actual testers on what they want to see?
I wouldn't interpret the current manual as requiring the VIN to be attached to a 'main structural' part of the chassis...
loggyboy
posted on 20/8/13 at 01:08 PM |
The chassis is the chassis, doesnt matter if its on the main chassis rail, or one of the cross members, it just cant be on a wishbone, or a pushrod,
or engine mount bracket etc.
The wording is clear enough.
The Stamped in VIN must be marked on the chassis, frame or other similar structure which is not easily removable, on the right hand side of the
vehicle when viewed from the rear.
[Edited on 20-8-13 by loggyboy]
Mistral Motorsport
adithorp
posted on 20/8/13 at 01:50 PM |
I think that "...is not easily removable..." is the bit they're interpreting the way I said. Now, I'm just going off reports
from people who've failed IVA on this, but by all means, interpret it anyway you like.
jps
posted on 20/8/13 at 01:54 PM |
quote: Originally posted by adithorp
I'm just going off reports from people who've failed IVA on this
Now some pics of 'what fails' would be good! :-D
The Black Flash
posted on 20/8/13 at 02:25 PM |
I've emailed VOSA twice for clarifications on the manual, and they've been very helpful both times. Takes a few weeks to get the
definitive answer but they at least keep you informed. Worth dropping them a line to get the official word...
jps
posted on 20/8/13 at 02:39 PM |
How do you contact them? I've been struggling to find contact details... Can't find a phone number or email address for the testing
stations...?
907
posted on 20/8/13 at 04:47 PM |
I can't quite get my head round a marking system that involves stamping a plate and welding it on.
If some unscrupulous "****" wants to change the I.D. of the car they just grind it off and weld on another.
Who will be able to tell it's been tampered with?
Might as well use a couple of pop rivets. ( shrug )
Paul G
40inches
posted on 20/8/13 at 06:03 PM |
I printed the VIN in Word, taped it to chassis, and engraved through the printing, using a cheapo Lidl battery engraver. I sprayed over with clear top
coat.
![](/galpreviews/Chassis number2.jpg) ![Description](/gallery/Chassis number2.jpg) Description
[Edited on 20-8-13 by 40inches]
doobrychat
posted on 20/8/13 at 06:17 PM |
same as above..
MsD
posted on 20/8/13 at 07:26 PM |
Is there a specific size? Or just make it big enough to be readable?
Mark.
loggyboy
posted on 20/8/13 at 07:40 PM |
Mark.
Min 3.5mm tall letters.
Mistral Motorsport
paulf
posted on 20/8/13 at 08:37 PM |
I stamped my VIN on a bit of steel strip and then sikaflexed it to the chassis, if you leave a bead of adhesive around the outside and the paint over
it it will look as if it is neatly seam welded.I also have a riveted plate on the opposite side of the chassis .
Paul
The Black Flash
posted on 20/8/13 at 09:58 PM |
stations...?
approvals@vosa.gov.uk
That gets you an answer from their central policy unit, it's not the testing station, but then should be a more definitive answer.
loggyboy
posted on 20/8/13 at 11:09 PM |
Paul
Why on earth would you risk a £90 retest just to avoid spending a few mins welding it on?
Mistral Motorsport
Dick Axtell
posted on 21/8/13 at 08:37 AM |
quote: Originally posted by 907
I can't quite get my head round a marking system that involves stamping a plate and welding it on. If some unscrupulous "****" wants
Who will be able to tell it's been tampered with? Might as well use a couple of pop rivets. ( shrug )
That also crossed my mind, although I've done it precisely that way.
![](/galpreviews/Chassis_VIN_04.jpg) ![My_VIN_Plate](/gallery/Chassis_VIN_04.jpg) My_VIN_Plate
In retrospect, I would have preferred to engrave the VIN directly on to the chassis. There is another VIN stamped on to the chassis, on a less
critical member, just under the passenger seat.
jps
posted on 17/10/13 at 12:39 PM |
Here's how I've done it in the end - etched onto a 3mm plate - then welded onto a bulkhead - seam welded all the way round.
Sorry about the image size!
![](http://meandthekitcar.files.wordpress.com/2013/09/vin-pic.jpg)
Irony
posted on 17/10/13 at 05:21 PM |
Paul
A few minutes? Not all of us have welding facilities at home. If I have to weld this it will mean hiring a man to come and do or trailering the car
somewhere.
MsD
posted on 17/10/13 at 06:27 PM |
Does anybody have or is there a guideline on VIN numbers? Length/ how many numbers/letters?
Thanks, mark.
loggyboy
posted on 17/10/13 at 08:38 PM |
Its In the IVA manual.
Mistral Motorsport
