<<  1    2    3  >>
Author: Subject: At last my build starts
rick1962uk
posted on 27/4/14 at 09:13 PM Reply With Quote
Originally posted by scutter
Looking good there fella, keep it up.
I'm over at Brize Norton if you fancy chewing the fat?
Regards Dan.
hi dan would love to a bit tied up with racing at the moment but should have a bit more time on my hands in a month or so
rick1962uk
posted on 5/5/14 at 12:25 PM Reply With Quote
Engine in place
Exhaust has clearance
Prop should have enough clearance
Lower Mounts Done
Started to make the top cradle but ran out of steel
Bonnet fits but is tight
rick1962uk
posted on 14/5/14 at 06:17 PM Reply With Quote
Finnished off the engine cradle
front bracket done with crush tubes
also started with the seat brackets
rick1962uk
posted on 14/5/14 at 06:18 PM Reply With Quote
Front end done
scutter
posted on 15/5/14 at 02:38 AM Reply With Quote
A little crossbracing in there can't hurt.
ATB Dan.
rick1962uk
posted on 15/5/14 at 06:47 PM Reply With Quote
i know will have a go at working it out a bit later when i know it wont get in the way of anything the amount of times i have built something then have to remove braces or brackets to let other items fit must be in the hundreds
rick1962uk
posted on 18/5/14 at 08:19 PM Reply With Quote
Had a slow weekend on the car had a lot planed but had an sos from a fellow 7 owner just about sorted that one so on with the roadster so far spent about 3 hours trying to get the seat and steering wheel in the right place sort one then the other comes up wrong but think im there
Darek32
posted on 18/5/14 at 08:39 PM Reply With Quote
Hi nice work there.
One thing , I've noticed on the last picture upper wishbone is on the wrong side or upside down.
Cause transit drag link goes down . should look up.
[Edited on 18/5/14 by Darek32]
rick1962uk
posted on 19/5/14 at 06:00 PM Reply With Quote
Many thanks have moved them around so many times will check tonight
rick1962uk
posted on 20/5/14 at 05:15 PM Reply With Quote
Managed to get the steering column done looks like i will have to change the rack to get a decent angle
http://i1298.photobucket.com/albums/ag52/rick1962uk/P1010062_zpsb4265f69.jpg
rick1962uk
rick1962uk
posted on 27/5/14 at 08:11 PM Reply With Quote
Welded up the rear uprights today got the stick welder going to cope with the thick plates
put a coat of paint on
now its starting to look like a kitcar and not a pile of parts
rick1962uk
posted on 3/6/14 at 08:00 PM Reply With Quote
Almost finished the pedal box going for a motorcycle rear cylinder for the clutch as car ones seem to have to big pistons and i want a smooth clutch action im going for a 12mm one
rick1962uk
posted on 25/8/14 at 12:58 PM Reply With Quote
Managed to have a few hours on the car so cracked on with the steering its a bit tight but will have a go at modifying it for a few mm of clearance
rick1962uk
posted on 2/11/14 at 12:36 PM Reply With Quote
Had a good morning on the kit got the rad fitted and almost sorted the gear linkage
Rosco86
posted on 2/11/14 at 05:38 PM Reply With Quote
Looking great mate! Can't wait till I'm up to your stage
rick1962uk
posted on 2/11/14 at 05:45 PM Reply With Quote
its taken nearly 2 years on and off but going to have a big push to finnish it this winter
rick1962uk
posted on 4/11/14 at 04:57 PM Reply With Quote
had almost a full day on the car today so managed to pull it all apart a bit sole destroying but knew it had to be done finished welding all the bits i couldnt get to with the engine in ground down the welds and even got a first coat of paint on so now feeling great as 1 more coat then it can go together for the final assembly babby sitting the grankids sunday so might take them down and get them working 4 and 11 should have a few uses even if its getting into small gaps
rick1962uk
posted on 11/11/14 at 06:37 PM Reply With Quote
Feeling a lot better now its going back together again floor and back panel in i now hate rivets
rick1962uk
posted on 18/12/14 at 06:04 PM Reply With Quote
Pedal Box al done
it was a bit tight
Scuttle was a bit to short
Now to cut the front end to fit
Roll bar tacked ready to cut the supports
Suport plate welded
Brakes and wheels fitted to see how they look going for 15s
rick1962uk
posted on 19/12/14 at 06:12 PM Reply With Quote
First support bar tacked in place took ages to get the joints right
Rosco86
posted on 19/12/14 at 10:17 PM Reply With Quote
Looking sweet!
rick1962uk
posted on 21/12/14 at 04:16 PM Reply With Quote
Just picked up yhese with 888 tyres on
scutter
posted on 21/12/14 at 06:06 PM Reply With Quote
Looking good there fella. Making much better progress than me.
ATB Dan.
rick1962uk
posted on 21/12/14 at 06:48 PM Reply With Quote
Dan take heart it stagnated for ages i was working on it but getting no ware then it just started to come together i found that making a plan of work with loads of small tasks worked IE i didnt make a list and put make wishbone armes i instead put down cut tube , make bush tubes ,make jig etc it makes you feel a lot better and it looks like your getting there
<<  1    2    3  >>
