New Topic New Reply
Author: Subject: ERW Suspension
joneh
posted on 27/9/13 at 07:50 PM Reply With Quote
ERW Suspension
Evening all,
For the Haynes Roadster, is ERW ok for the suspension tubes? Or have I ordered the wrong stuff?
Steel turned up today, chassis started woohoo!
Jon
Slimy38
posted on 27/9/13 at 08:16 PM Reply With Quote
It's what I'm going to use, although I've upped the thickness slightly. I was told that it should be ok as long as the seams are the right way round, IE hidden by the plate.
Talon Motorsport
posted on 27/9/13 at 08:25 PM Reply With Quote
2mm wall ERW will be fine after all it's held in place by 1.5mm walled box section.
joneh
posted on 27/9/13 at 08:34 PM Reply With Quote
I ordered 1.5mm though. Is this too thin?
Talon Motorsport
posted on 27/9/13 at 08:52 PM Reply With Quote
Just means your wishbones will be expendable I make mine in 2mm to cover my own back with what ever the end user throws the car at.
ashg
posted on 27/9/13 at 09:16 PM Reply With Quote
my lower wishbones on the roadster are 2.5mm cold drawn seamless. spend the money do it right do it once. i have seen plenty of bent erw wishbones over the years
at the end of they day you will do what you want to do. I can only advise from my perspective.
This is my Perspective I built a roadster (and other cars).... from scratch...every single part.... i have driven it for nearly 4 years very very hard, for thousands of miles all over europe, my wishbones are not bent. they didn't even bend when i hit a rear wheel on curb at 50mph, destroying a wheel and bending the upright carrier.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
joneh
posted on 28/9/13 at 08:55 AM Reply With Quote
Yup, thanks for the advice, will get some seamless thicker stuff for the suspension.
I'm sure I'll find a use for the 25mm ERW.
I'll use the 19mm stuff for the rear boot area...
motorcycle_mayhem
posted on 28/9/13 at 11:56 AM Reply With Quote
Someone on here was suggesting a while back that 1.2mm was great for wishbones, after I had made a comment that I wouldn't want to go any thinner than 1.6mm. Being totally stupid, I actually made mine from mechanical 2mm CDS. Stupid, but I'm happy with my stupidity, they're working well.
Bottom rear arm, to the corner of the chassis is the one that takes the load. On slicks, the force through this a good 1-2 tons, safely in compression though....
New Topic New Reply
