Furyous
posted on 12/12/13 at 12:21 AM |
Repositioning a Chassis Member
I need to move a chassis member in my engine bay in order to clear the sump.
I know that ideally it would be best to replace the whole length, as in the green photo.
But would I get away with replacing it as in the red photo?
That would add a bend to the bar but it would save a lot of work in keeping the suspension mount in the right place.
snapper
posted on 12/12/13 at 04:56 AM |
Add some small triangles of plate at both joints and that will be ok
I eat to survive
I drink to forget
jossey
posted on 12/12/13 at 09:28 AM |
as above its not ideal but get some 5-8 mm steal top and bottom in a triangle and your ok. i had a fabricator repair my avon after a
"oppps" and he did the same. he was happy with the repair on 1 of the rails he replaced. that said its not ideal. so in the end i cut it
all out and spent hours grinding it for him to come back and weld the new full piece in. and i also now have the triangles too. any joint where it
meets at the unusual angle.
David Johnson
mark chandler
posted on 12/12/13 at 02:56 PM |
In your photo above you are neglecting to show the other diagonal that abuts at the same join, ideally if you reduce one you will need to cut and
extend the other so when viewed from all you see are triangles.
Regards Mark
Furyous
posted on 16/12/13 at 08:38 AM |
I cut the rail out and put the engine in with the new sump. It turns out the red photo above still doesn't give enough room. So I've done
it as in this photo:
I'll add some triangle plates across the corners and tidy it all up tomorrow.
