TTK77
| posted on 3/11/04 at 06:01 PM |
Uniball wishbones
How have you done wishbones if you have used uniball rod ends in upper and lower frontwisbones chassis connections?
Pictures somewhere?
SORRY poor english but I hope someone understand what I ment..
[Edited on 3/11/04 by TTK77]
| posted on 3/11/04 at 07:07 PM |
do you mean, 'how do you connect wishbones to the chassis via rod ends rather than bushes?'
not sure myself but if no one comes forward with answers i'll dig out some photos from an old thread.
TTK77
| posted on 4/11/04 at 07:53 AM |
Thats what I mean!!
| posted on 4/11/04 at 08:28 AM |
http://forum.locostbuilders.co.uk/viewthread.php?tid=18376
in this thread several pictures were posted. Im sure someone can sort out more details.
Terrapin_racing
| posted on 4/11/04 at 11:34 AM |
Does this illustrate it OK?
Terrapin_racing
| posted on 4/11/04 at 11:35 AM |
and ..
locoboy
| posted on 4/11/04 at 12:43 PM |
Terrapin,
Just out of interest why is the top rear most mounting in a different configuration to the rest?
Locoboy
TTK77
| posted on 4/11/04 at 01:10 PM |
Thank U very much
stephen_gusterson
| posted on 4/11/04 at 02:38 PM |
also.....
ive ben told that really the joints shouldnt take axial (sideways) loads if its to be avoided. My car has them in the same way your has - ie not the
recommended way.
Axial loading is approx 15% of radial loading......
F1 cars, im told, have them turned thro 90 degrees.
Terrapin_racing
| posted on 5/11/04 at 09:25 AM |
You will note that the top rear bearing is mounted at 90deg to ensure the load is addressed correctly. I'm using 10,000lb rated 3/8" UNF
bearings. All I can say is experience is that this configuration is OK as they have been doing this since 1963 on the Terrapin. I'll post some
more examples to show how loads are tackled.
http://www.bakerprecision.com/rodpick.htm
is useful
Terrapin_racing
| posted on 5/11/04 at 09:26 AM |
and
Terrapin_racing
| posted on 5/11/04 at 09:27 AM |
and
