Author: Subject: Dash mount indiacator
Gaz4562
posted on 25/2/15 at 09:46 PM Reply With Quote
What self cancelling dash mounted indiacator switches do people use that is IVA ok. Cheers
gremlin1234
posted on 25/2/15 at 11:05 PM Reply With Quote
self cancelling is not required for iva !
loggyboy
posted on 26/2/15 at 07:35 AM Reply With Quote
Any dash mounted self cancelling will need to be electronicly controlled. there are systems out there to do that. Best and cheapest is to use the stalks intended for your column (assuming you're using a factory/car based column.
As above, its not an IVA requirement.
Mistral Motorsport
Gaz4562
posted on 26/2/15 at 08:00 PM Reply With Quote
Didn't really want to use the sierra stalks, wanted a clean looking Column. I thought westfield did a self cancelling dash switch, but I can't find it. I know I don't need one, just thought it would be a good idea.
loggyboy
posted on 27/2/15 at 12:51 AM Reply With Quote
Iirc the westfield one is an electronic one.....
and expensive
http://parts-shop.westfield-sportscars.co.uk/index.php?route=product/product&product_id=370&search=switch
[Edited on 27-2-15 by loggyboy]
Mistral Motorsport
luke2152
posted on 27/2/15 at 09:28 AM Reply With Quote
some bike ones are self canceling
HowardB
posted on 27/2/15 at 09:57 AM Reply With Quote
my landrover has a clockwork indicator of vintage bently ilk. Depending on how far the leaver is pushed in each direction as to the duration of the flashing.
It doesn't take long to get used to it, and always - always confused any one else that drove it,.. .
lol
Howard
sparkyj83
posted on 27/2/15 at 03:41 PM Reply With Quote
I just have a alloy 3 position togle switch works fine and just passed Iva with no problems
