GaryMeades
posted on 30/11/04 at 06:43 PM |
G1 & G2 Position along C for xflow
Hi
Please can somebody confirm the position of tubes G1 & G2 (along C) when fitting a xflow.
The book seems to quote 7" and then changes it mind and quotes 5"!
Gary
We choose to build, not beacuase it is easy but because it is hard, because the gaol will serve to organise and measure the best of our energies and
skills, because the challenge is one that we are willing to accept, one we are unwilling to postpone, and we intend to win. - J.F.K (almost)
phelpsa
posted on 30/11/04 at 09:01 PM |
Place them where they need to be! The book is only a guide, and is only meant to be a guide.
Adam
James
posted on 1/12/04 at 08:30 AM |
I'd sit the block in the chassis then see where they need to be for the engine mounts to fit ok! With a Pinto atleast it's worth doing
this as the starter motor gets in the way- not sure about the Xflow.
Hope that helps,
James
DavidM
posted on 4/12/04 at 08:41 PM |
They need to be different one side to the other. The passenger side is further out to clear the xflow starter motor. I'm with James and sat the
block in the chassis to get the correct fit.
It's much easier than cutting it out later on because it fouls.
atb
