vindicator
posted on 21/5/15 at 06:52 PM |
what coolant bottle has this come off
Hi Folks,
Have been having a few issues with radiator coolant being dumped out of the overflow cap when hot. The engine temp gauge shows just over 80 when out
for a run and does not move until the engine is switched off. The coolant pipes are warm, not hot.
Took the car out for a quick spin and later looking around the engine, I noticed that there was a hissing noise coming from the cap. So i need a new
cap.....
Trouble is someone gave me the coolant bottle when building over 6 years ago and I need to identify it so that I can get a new cap.
Does anyone recognise the bottle and which manufacture/model of car it came from.
The bottle has 3 inlet pipes, the main pipe is vertical under the bottom. It also has the letters RCF 10041 marked on the side.
TimR
coolant overflow bottle
timr.spaces.live.com---build blog
KitCatE1
posted on 21/5/15 at 07:12 PM |
looks like this little fella off a metro:
http://www.rimmerbros.co.uk/Item--i-PCF10041
or
http://metropower.org.uk/forum/forums/printer-friendly.asp?tid=67779&mid=
[Edited on 21/5/15 by KitCatE1]
posted on 21/5/15 at 07:14 PM |
Looks a bit like the one I got out of a mid 2000's Corsa
posted on 21/5/15 at 07:21 PM |
Cap off a Rover 25 or 45 or 820 will fit so will some Fiat ones.
vindicator
posted on 21/5/15 at 07:22 PM |
Thanks KitCatE1, This is the one. The pipes on mine are in plastic and moulded into the bottle, where in your pic they are either steel/ali...
At least I can go and order a new cap now
TimR
ian locostzx9rc2
posted on 21/5/15 at 08:57 PM |
Looks like a Vauxhall corsa expansion tank .
