New Topic New Reply
Author: Subject: Fuel lines
Paul Knapp
posted on 19/9/15 at 03:14 PM Reply With Quote
Fuel lines
Hi guys, new to the forum as you can see.
Im building a time attack evo for next year and have a question for you:
Fule lines inside or underside? the car will have a flat floor, splitter, and defuser.
Thanks Paul
Slimy38
posted on 19/9/15 at 03:18 PM Reply With Quote
It depends on what you term 'inside'. In the cockpit is a bad thing, but outside the flat floor would be similarly bad. Most cars have fuel lines exposed to the outside (so as not to potentially fill the cabin with fumes), but tucked away out of reach in various nooks and crannies. The flat floor would then go underneath.
Paul Knapp
posted on 19/9/15 at 03:21 PM Reply With Quote
Thanks for the reply,
yes I meant in the cockpit, and on the floor between the floor chassis and the flat floor.
Adamirish
posted on 19/9/15 at 04:21 PM Reply With Quote
Inside will stop them from getting damaged but it does stink of fuel. My boss has 2 rally cars both of which I have driven. One has normal braided fuel line and it stinks. The other has Kevlar lined lines and there is no smell at all. I would say its expensive though.
MK Indy 1700 Xflow
New Topic New Reply
