<<  1    2  >>
New Topic New Reply
Author: Subject: Sierra based chasis
mathew
posted on 12/10/02 at 11:27 PM Reply With Quote
Sierra based chasis
Can any body tell me where i can find dimensions for a sierra based chassis or get a plan from
Mathew
locost7-online.com
posted on 13/10/02 at 08:38 AM Reply With Quote
if you look xxxxxxxxxxxxx you can buy a book, called build you own tiger sportscar.
www.xxxxxxxxxxx.com/xxxxxxxx.htm
Ahem! Try www.locostbuilders.co.uk/books --Chris
mathew
posted on 13/10/02 at 05:26 PM Reply With Quote
Thanks for the reply.
At a last resort I could build the tiger sportscar mentioned on your site but is there anyone out there that has the suitable plans to modify the plans given in the book (build your own sportscar for under £250)that I could use as mk1 and mk2 escorts are hard to come by
thanks
Dunc
posted on 13/10/02 at 05:32 PM Reply With Quote
The main difference from 'the book' will be the rear suspension setup. A good start would be to look at the McSorley Plans. The 442, larger chassis, would be a good start. Leave the transmission tunnel until you've got and measured your donor gearbox and trial fitted it.
mathew
posted on 13/10/02 at 05:55 PM Reply With Quote
Where can i find the Mcsorley plans and is it the same style as the the locost
thanks
bob
posted on 13/10/02 at 06:02 PM Reply With Quote
thanks
http://mcsorley.net/locost
Findlay234
posted on 13/10/02 at 07:32 PM Reply With Quote
ive got a CAD plan for a sierra based chassis it's 2 inches wider than the book chassis and its mildly longer as well, i think i remember about 4inches longer. i can email it to you if you want it. i dont know how much help it will give you.
cheers
ludsonline
posted on 14/10/02 at 05:28 AM Reply With Quote
I found plans for the Sierra IRS Rear on the net last night might be of some help picture with dimensions in the photo archive
rallyslag
posted on 14/10/02 at 12:56 PM Reply With Quote
where from?
Old chinese proverb: "If a man speaks in a forest, and no woman hears him, is he still wrong?"
john_s
posted on 14/10/02 at 05:12 PM Reply With Quote
I've built my chassis for a sierra donor from the McSorley +4 plans. Am currently working out the rear suspension. It's going to be loosely based on the tiger avon book.
John
John Singleton
Gremlin
posted on 15/10/02 at 12:40 PM Reply With Quote
This is really for McSorley but have you any plans of adding a irs version to your McSorley collection?
I would try to model one but no idea where to start or how to use autocad. Im a computer tech and fix the software if users have problems with it but dont really use the software i support.
Dunc
posted on 15/10/02 at 04:11 PM Reply With Quote
John S,
What are you using to work out your rear suspension?
Dunc
James
posted on 15/10/02 at 05:10 PM Reply With Quote
Although I'd always recommend CAD if people start messing with the chassis- particularly if changing the front end you don't really need it for the rear as it's far less complex. Have a look at the MK website to get an idea of how MK do it. Then study the pictures on this site- Bass has put up pictures of the Tiger book. Then look around for other pictures on websites.
Also, there is an IRS picture in the fuel tank section of The Book which I'm sure you've spotted.
If all this fails buy the Tiger Avon book: http://www.amazon.co.uk/exec/obidos/ASIN/1903706092/locostbuilder-21
and translate their plans onto your Locost!
With all these it's not that hard to get the basics of how to do it!
HTH,
James
john_s
posted on 15/10/02 at 05:43 PM Reply With Quote
A rather low-tech approach... some lumps of metal and a hacksaw!
The plan is to make wishbones to the tiger book dimensions (in terms of distance between inner and outer mountings), and position rails as close as possible to the tiger positions to fit into the McSorley +4 chassis.
I'm making hub carriers from a piece of channel cut from a length of 120 x 120 x 5mm RHS, and will have to modify the wishbones slightly to connect to this.
John.
John Singleton
fastenuff
posted on 15/10/02 at 06:05 PM Reply With Quote
james you must have a 2nd edition book.
Ingmar
Gremlin
posted on 15/10/02 at 11:05 PM Reply With Quote
James
Thanks for that. I already have the tiger book but was not that happy with the back half of the chassis. The front was nice and well thought out but the back looks like it has been thrown together and i was just trying to make things a bit easier for me as im limited on cash and cant be remakeing bits.
I will deffinatly look on the photo section but i was hopeing buy producing the cad drawing i would get a few dimensions.
Oh well! Off to the garage with a bit of paper and a ruler.
James
posted on 18/10/02 at 11:16 AM Reply With Quote
Fastenuff,
Yes I do- I've looked at both and I definately prefer the 2nd. Saying that though, a lot of people have had trouble with the bit of the chassis where the rear shock mounts (the 102mm*102mm*3mm plate) because of the lack of clarity in the 2nd book. Looking at the 1st book this area is much clearer in several pictures.
It's page 95 and you can practically build IRS off that alone.
Gremlin,
You're right, trial and error fitting definately gets through more metal- my pile of RHS that's now too short to be used is growing rapidly!
I planned mine out and used trigonometry to calculate what I could in advance but some data is impossible to find as what's needed to calculate it is missing from The Book.
I agree the Tiger plan doesn't look ideal but if you can't/don't want to/don't trust yourself to design it yourself then I guess it'd be a big help.
Looking at the Stoneleigh photo archive here (when it works again) and The Book it's not that hard to come up with something that fits the original style of the rest of the chassis.
James
Hallsy
posted on 18/10/02 at 04:04 PM Reply With Quote
There is a lot of talk of using the +4 or +442 plans if using a Sierra rear suspension set up. Is this necessary or just a preference as i am looking at building the standard "book" chassis as per the McSorley drawings and will be using a Sierra donor?
john_s
posted on 18/10/02 at 05:48 PM Reply With Quote
The extra 4 inch of width suits the sierra donor better as it has a wider track than the escort.
The extra height of the +442 could be useful due to how tall the pinto engine is. I'm just using the +4 plans; am going to find out the hard way if a pinto goes in without too much bother!
John Singleton
Hallsy
posted on 19/10/02 at 05:35 PM Reply With Quote
So if using the Sierra steering rack (i'm presuming it can be used) and the Sierra drivetrain it is advisable to use the +4 drawings?
As for the rear suspension arms would you just replicate the front ones and position them to suit the position of the rear driveshafts and hubs?
locodude
posted on 19/10/02 at 06:23 PM Reply With Quote
Why use + anything plans. The MK Indy chassis is basically a locost with an IRS back end and extended front wishbones. It even uses the donor driveshafts. The rack is modded to prevent bump steer. The only reasons for + something chassis is really being a bit lardy/ ease of engine install. Don't forget that the bodywork will be harder to source if going bigger! Just a few peneth of thoughts!
Hallsy
posted on 19/10/02 at 06:34 PM Reply With Quote
Right, so if using the standard chassis plans the Sierra front track and rear 'shafts can be used as long as the front wishbones are extended ( can these be bought to meet this requirement?) ensuring that the geometry is still the same and that rear wishbones are made up to suit the position of the rear hub/'shaft assembly?
I would like to stick with the standard chassis plans (McSorley) but use a Sierra as donor and so irs rear, will i survive!!?? I am an engineer by trade so i should be able to!!
ludsonline
posted on 19/10/02 at 06:49 PM Reply With Quote
Sierra IRS Chassis
Hi Hallsy,
I have ordered the Tiger book from Sudbury Library and will scan the chassis pages when I get it and e-mail them to you if you want
James
posted on 19/10/02 at 07:14 PM Reply With Quote
Hallsy,
yes, you can buy the wishbones from MK to suit the Sierra track with a standard chassis. I asked about this at Donnington and it's not cheap but possibly a good idea.
Remember if using Sierra you'll also need to enter the great balljoint search or get your Sierra hubs' lower hole bored wider to suit a Cortina balljoint.
I also asked at Donnington about the modified rack. There's an additional reason aswell as for bump steer that it's chopped: the fact the with the standard rack the mounts end up outside the car! MK chop it so as to get the rack mounts where they would be on an escort.
For both rack and hubs you can get them from MK on an exchange basis.
With Sierra you'll also need to make/buy rear uprights. These are about £30 each from MK. You'll also need hub insert bushes for the front hub so it can take the Sierra top mount. You can make these (not too hard but need a tapered hole for the BJ) or buy from MK. (£20 each!!!).
Basically my advice would be only use a Sierra if you really can't find/don't want a MK2 because it is a lot more expense and hassle...
I'm doing it so I should know!!!
James
[Edited on 19/10/02 by James]
Hallsy
posted on 20/10/02 at 11:34 AM Reply With Quote
ludsonline, cheers mate, that would be much appreciated.
James, i could machine the hubs easily enough at work, to accept a cortina ball joint. As for rack, if u were to chop it and shorten it (is this just a case of cutting and welding back together?) then surely you could just use standard wishbones as the track could be made to be as the escort.
I see what u mean about exta cost, its just that o thought it would be alot easier to find a sierra than an escort, i s'pose i haven't actually tried looking for an escort yet though, i'll have to see what happens i guess.
<<  1    2  >>
New Topic New Reply
