Author: Subject: Luego zetec electrical gremlin
Luego.2.0
posted on 3/11/15 at 04:26 PM Reply With Quote
Hi all
Took the battery off to charge it. Since putting back on I've
Noticed the side and head lights at the front , both brake and side lights on the rear and are not working. Indicators hazards and all other functions are working ok. I've checked all the viable fuses and swapped relays around, all with no joy?
Anybody got any ideas before I hurt my head banging it on the wall.
Cheers steve
Veinto 2.0 black top.
Jenevy throttle bodies
Omex ecu
kj
posted on 3/11/15 at 04:35 PM Reply With Quote
Bad earth all earth leads back on nothing worked loose.
Think about it, think about it again and then do it.
Luego.2.0
posted on 3/11/15 at 06:26 PM Reply With Quote
They all looked ok I'm going to go back down the the unit
And have another check.
Omex ecu
posted on 3/11/15 at 07:57 PM Reply With Quote
What switch gear do you have? What wiring loom? Did you refit all disconnected cables? Might be worth checking at the switch for a live feed in and out , same for the brake lights .
Luego.2.0
posted on 4/11/15 at 11:56 AM Reply With Quote
I think it's a luego made loom. Ford switches on the colour
Had a llom around after wiggling some wire near bottom of the rack the lights came back on.
Only issue now is the brake lights aren't working. Is the a switch for the lights I couldn't see one on the pedal box?
Omex ecu
posted on 4/11/15 at 06:33 PM Reply With Quote
It depends on which type of switch the original builder fitted , no two kit cars are built the same . Chances are there is a pressure switch installed in the front pipe work , trace the pipes and check for a switch. Hydraulic switches do seem to cause a few problems in kit cars , do a search it's been covered several times.
Luego.2.0
posted on 4/11/15 at 09:17 PM Reply With Quote
Thanks mate
Just had a look online to see what I'm looking for. Hopefully easy fix as im at rockingham on Sunday.
Omex ecu
Luego.2.0
posted on 5/11/15 at 01:12 PM Reply With Quote
Thanks rusty nuts
Found the sensor just under the nose cone on the pipework
Like you said. Found a replacement in a little motor factors in milton keynes
Thanks again mate
Omex ecu
