bi22le
| posted on 3/1/16 at 05:06 PM |
Rose joint fork to weld to wishbone
Not sure if my terminology is right but I need a pair of these.
I am collating bits to fit an ARB and the down links will be rose jointed. The end result is a fork / clevis thing to weld to my front wishbones to
bolt my rose joints to.
I could make it out of 3 sided box.
Any off the shelf items ?
Please read my ring story:
Rich J
| posted on 3/1/16 at 05:36 PM |
Try "laser cur bracket" or "shock mount autograss" in a well know auction sites search bar - maybe something to fit your needs
there
smart51
| posted on 3/1/16 at 05:39 PM |
I used 3 sides of a square tube to mount my ARB. The small sides were tapered towards the top so there weren't any sharp corners. You can just
about see them in this pic.
  Front with cycle wings
mark chandler
| posted on 3/1/16 at 06:55 PM |
It only takes a couple of minutes to cut some out of 1/4 plate, if you are attaching to round tube then cut a hole to match the bone, another
3/4" from it to match the Rose joint then cut out with a hacksaw, literally 5 minutes work.
| posted on 3/1/16 at 08:41 PM |
McGill motorsports on the bay sell clevis parts...
Any good?
Clevis Joint 5/16" UNF 5/16" HOLE Rally Autograss Threaded Fork
[Edited on 3/1/16 by coozer]
hizzi
| posted on 3/1/16 at 10:32 PM |
second for mcgill they are near me and very helpfull. phone them they have more than on the web page
bi22le
| posted on 3/1/16 at 10:44 PM |
That's what i am thinking. 6mm plate the appropriate thickness for this sort of work? I am also going to have to weld some late to the chassis
for the ARB bushes to mount to.
