nightracer36
| posted on 8/2/16 at 04:56 PM |
mx5 rear lower suspension brackets
hi, does anyone know the correct measurements for the positioning of the lower rear suspension brackets? are they directly below the upper ones?
I've checked the Saturn sports car manual but does not give details, just details on the upper brackets, any help greatly needed. Ron.
| posted on 8/2/16 at 05:03 PM |
Look at the scrap car collection thread as there's a guy getting rid of a stripped one - he may be able to measure for you.
garyt
| posted on 8/2/16 at 05:50 PM |
Hi here is the bit that says about the rear lower wishbones;
Rear Lower Wishbones – These are similar to the Sierra based wishbones but adapted at the outboard end to fit around the Mx-5 uprights. The inboard
adjusters are necessary to modify camber of the uprights as the upper wishbones do not have the room for the adjusters. They can also be used to make
small changes in toe-in to the rear uprights. Suspension brackets are in the same location as the Sierra based chassis. They are fabricated to the
jigs below:
there is a picture of the jig underneath it with the dimensions page 20 of the Saturn instructions
and here reference the lower rear mount positions on page 9
Rear Wishbone Brackets – Lower rear brackets are located in the same location and spacing as the manual with the upper brackets placed as shown below
facing outwards on rail RS7 and RS7a 90mm from the outer edge to the centre and 203mm centre to centre
and there is a drawing of the rear uppers in my photo archive
hth regards Gary
remember we are not mad just creatively insane !!!!!
garyt
| posted on 8/2/16 at 05:52 PM |
here is the rear top wish bones with the relavant bracket postioning at the top of page 10
[img]
[/img]
Gary
garyt
| posted on 8/2/16 at 05:56 PM |
f your Saturn plans don't have these details , pm me your email address and I'll copy my version to you
Regards Gary
