<<  1    2  >>
New Topic New Reply
Author: Subject: Lotus 24 / 25 / 49 drawings
ftaffy
posted on 10/6/16 at 07:30 AM Reply With Quote
Hey Guys,
A fairly generic question, i have a few that are around on the web but does anyone have
a) Any photos/drawings showing the assembly of the lotus 25/49 mono?
Be interested in the join of the inner and out skins around the cockpit - cannot get my head around that part to be honest and have alternatives in mind to skip trying to do that as i can see it going pear shaped very quick.
The steel bulkheads - have a theory of how to do it but would like to see if its on the mark
Also a better res of this one would help
Lotus chassis blueprint
And this one of the 25
b) Drawings of the lotus 24 chassis?
Have the blue one which shows the chassis, which i can draw up the frame when combined with a series of photos i have come across but i will need to guess some parts.
Have CAD models of the skins of both which is useful for trying to size things up but i will be stretching to fit a normal human so a redraw is in order.
Not doing exact replica but obviously the more information the better
Thanks,
Taffy
[Edited on 10/6/16 by ftaffy]
Sam_68
posted on 10/6/16 at 09:36 AM Reply With Quote
The 25 and 49 monocoques were quite different: the 25 was a simple 'bathtub', with an unstressed moulded GRP upper bodyshell sitting on top of it, whereas the panels on the 49 extended up and round to form the upper cockpit, scuttle and rear bulkhead. And, of course, the key feature of the 49 was that it stopped at the rear bulkhead and used a stressed engine, whereas the 25 and other early monocoques projected the side torsion boxes rearward on either side of the engine.
This is a 27, but it's fundamentally very similar to the 25 (except that the rear 'booms' on the 25 stepped down to clear the exhausts on the V8) and is the best picture I've got that shows the area you're interested in:
This is a 25:
By way of comparison, this is a (replica) 49 tub under construction:
...and this is a cockpit shot of the finished article:
For the 25, get yourself a copy of the book Lotus 25 by John Tipler, which gives a fairly good description and several photos of the tub construction.
[Edited on 10/6/16 by Sam_68]
ftaffy
Some what i already have for anyone who comes across this thread
ftaffy
posted on 10/6/16 at 09:58 AM Reply With Quote
Thanks Sam, as always a help.
The 25 is a fairly simple beast to reverse engineer how to make (also offers the option to make a 24 get things sorted and swap into a 25 mono) but i like the 49 shape more.
I have been in contact with the builder of that replica, he has not been able to add much more around the skin construction.
What worries my is that the rivets are on the outside meaning the inner skin folds back under the outer... how the hell does that work?
Interesting to note the similarities between a 27 and 25, will go in look of some extra drawings.
For anyone really keen on the mono route take a look at this rebuild of a Lola, the square sided pods offer alot of benefits IMO.
https://primotipo.com/tag/john-turner/
Sam_68
posted on 10/6/16 at 10:24 AM Reply With Quote
This may be a better image:
It appears the the outer skin just laps over the inner panels.
ftaffy
posted on 10/6/16 at 10:44 AM Reply With Quote
Since i started this i might as well add some more detail photos to continue what Sam has helpfully posted.
Another of the replica tub, this shows the outside folded in along the edges - this is voodoo work to me!
And he is making a 2nd chassis which is a spaceframe and will be a fibreglass skins like that of a 24.
Another cockpit (have more detailed photos split by chassis number on a laptop that i need to copy off)
ftaffy
posted on 11/6/16 at 06:49 AM Reply With Quote
FYI used the one in the first post to make a model and it has some issues.
The best one to use is the "factory 49" perspective drawings with have a million lines on the nose cone to shape the body with. My preference was to use the front and rear and loft between them. That was you can add the missing folded underside. Though you miss out on some of the arc which is in the back of the car and its instead a straight line. Who ever drew this to start with didnt like the people who had to make it this damn car curves around X, Y and Z.
Starting to research building plans... to try and figure out how to do the cockpit area easier then how they have it even if it means some mods to the shape in that area as i can see benefits to the body wrapping as high as possible for stiffness.
Going to add an additional paid of bulkheads to be foam filled were the fuel tanks used to be for side impact protection, tank will only be behind the seat.
Too add some more interest to the thread:
This is an elfin 100 mono, looks to use a steel frame with partial AL skin for load carrying.
Gurney Eagle
And link to modeling mag for cars up to 1972
http://www.vsrnonline.com/Mags/MC/MC_Plans_1.htm
Taffy
Sam_68
posted on 11/6/16 at 07:43 AM Reply With Quote
The Elfin looks interesting - not a car we're particularly familar with in the UK.
The Gurney Eagle shares a lot of DNA with Lotus, having been designed by Len Terry, of course.
What's the purpose of the car you're building? My worry with a straight 'replica' of the techniques used to build '60's monocoques (single-skin panels an entirely riveted construction) is that they were reputed to lose almost 50% of their stiffness over the course of a single season's racing.
If you're not too worried about the 'authenticity' of the structure, it might be worth looking at a variation of the Reynard-built Formula Vauxhall Lotus cars, which were very simple, and have a reputation for being very robust, effectively using two huge aluminium honeycomb 'planks' set on edge as their main structure:
Just found these in my collection of a tub without the outer skins, that better illustrate the junction around the upper edge of the cockpit that you were worried about:
ftaffy
posted on 11/6/16 at 09:02 AM Reply With Quote
Thanks Sam, the plan was more about the style then rivet for rivet copy.
Besides using a 200hp v6 vs a 400hp v8.
Plan was to make a series of rolled shs ribs that have a frame which joins to the inner skin. Approx 6 were planned.
But open to other cost effective ideas thus the collecting of many ideas.
The issues with these is that the rolled outer skin went out of fashion quickly as I am guessing it was a pain to build and maintain be the square frames seen a lot.
Taffy
Sam_68
posted on 11/6/16 at 10:02 AM Reply With Quote
The issues with these is that the rolled outer skin went out of fashion quickly as I am guessing it was a pain to build and maintain...
Dunno... I'm not sure how much of it was that, and how much was the aerodynamic fashion for wedges that was introduced with the Lotus 56. Certainly, if you look at later cars like the Lotus 72 or Tyrrell 006, the sides of the tub are still 3-dimensionally curved, and just as difficult to form, but the curvature gets 'lost' visually against the overall wedge shape.
But, for sure, I'd rather do a simple, faceted-flat panel tub and hide it within a curved outer shell of glassfibre or CF than to roll a dual curvature aluminium outer skin.
ftaffy
posted on 12/6/16 at 07:17 AM Reply With Quote
This looks similar to early sketch I had done before trying to include the outer body work in the tub
Then as you said slip a skin over to suit.
ftaffy
posted on 12/6/16 at 08:24 AM Reply With Quote
FYI this is what i meant for the car to have ribs inside the mono.
1 more full hoop at the end of the cockpit opening and 2 more incomplete at the cockpit sides which will be capped off with a horizontal tube. The vertical tubes take the inner skin.
But bending these tubes would need to be CNC done as they have 3-4 separate curves in them each side... night mare or likely costly. Once they are done skinning would be so much easier. A flat topped single curve does not look right.
You could always cut them from flat plate and make up some frames but that would be likely to warp given suspension will need to be mounted off the front and rear of these not a great option.
Concerned its only you and me replying to this Sam...
Sam_68
posted on 12/6/16 at 09:41 AM Reply With Quote
It's when you find you're talking to yourself that you need to get really worried!
Feel free to take the conversation to U2U/e-mail, though, if you prefer.
Your arrangement looks very similar to this old Cooper:
Link to website with lots more chassis images - look under the 'phase 1 gallery' for the chassis construction.
Personally, I'd be more inclined to either use a simple, rectangular framework sandwiched between a couple of flanged sheets, to form a diaphragmn bulkhead arrangement, or else do away with the tubular framework and just use a sheet diaphragm (in which case, these days, you might consider honeycomb core material between the sheets to stabilise them).
Another alternative is a 'solid' bulkhead - in the old days, some manufacturers used cast magnesium, but these days we have the option of CNC machined aluminium. Moderately expensive, but simple and potentially very sexy!
This is the Retoga (a spaceframe, obviously, but shows the sort of thing that might be done):
And this is the Australian PRB aluminium monocoque 'Seven':
And a cast front suspension 'subframe' on a more modern single-seater:
ftaffy
posted on 13/6/16 at 07:57 AM Reply With Quote
thanks for the suggestions. nothing commerical being discussed and i see very few actual discussions about the basic design for a garage build. Most get into expensive honeycomb regions
Wasted a few hours sitting in the garage with the dog, who despite being named Shelby is no help. So i did quick lotus 24 and dropped in vw v6 i have on hand. The idea being i will see how the 25 goes shape wise, looks less double curve in the ally parts. i like that it does a dual function, a frame and then a skin feels like extra work for nothing if making a mono.
Also dropped into the f156 model i have, note the chassis is not what was under the skin normally! Its a rough one based on more modern designs but made to fit the skin, was what triggered the single seater but not likely to see the light of day.
In terms of mono design did some concepts of a slip skin but has draw backs.
Simple side pod design creates this
An option is to change the shape but the only benefit i see is if this is made into another piece and foam filled.
The stand alone mono tub would start to look something like this.
My current thinking is it is not an exact replica and as such a solution that gets me a dual function skin and mono is to just simply the body curves to allow them to be rolled in single radius bends. Need to add the nose and see about suspension points how it would look as it might just too off for my liking.
Came across this interesting chart about torsional stiffeness of various designs.
Sam_68
posted on 13/6/16 at 06:26 PM Reply With Quote
That looks a nice little model of the 25 - how long did it take you, and what software were you using? Any chance of scrounging a copy?
The stiffness table is from a book called Race Car Chassis Design & Construction, by Forbes Aird, I think, but it tallies with information I've seen elsewhere.
It's interesting in that the 25 monocoque gives about the same sitffness as the best current 'Seven' spaceframe chassis (without cage) but for less than half the weight (not a fair comparison, though, I know, given that it's a mid-engined single-seater).
The Lotus 79 figure is bang on the money, too, but the guy who designed it told me it was about half that after a season's racing, and feeling distinctly 'baggy'. Certainly not stiff enough to best exploit ground effect, and the 79's biggest flaw!
Also interesting, therefore, that the actual weight of the 24 and the 25 chassis are almost identical (ie. the advantage is stiffness, rather than weight). If you lose half the stiffness over a season or two due to the rivets fretting and the panels stretching/relaxing, you're left with no advantage... hence I think you need to think in terms of sandwich structures (massively better stiffness to start off with) and bonding as well as riveting, to make it worthwhile.
ftaffy
posted on 13/6/16 at 10:14 PM Reply With Quote
Sam U2U Sent.
I have a copy of the Race car chassis design and construction book on order/its some place between England and Australia. Read that it had some good information on monocoques... we will see how true that is.
The best for home building has been Stainfords and his references to the monopin.
Yeah was talking someone who has a chevron and they gave me some tips on how they did the bond/rivet set up, do have a decent starting point when i get to that detail. I glued and riveted the panels on my locost to make it stiffer and it was nearly 5000Nm/deg before any panels.
Will retrace your 25 drawing and see about modeling that up and as the shape looks nicer possibly for the home builder, though my preference is still the 49 but build ability may drive the design direction.
Appreciate the comments/photos.
Sam_68
posted on 13/6/16 at 10:30 PM Reply With Quote
My understanding is that bonding as well as riveting is only a partial solution to the problem of loss of stiffness, mind you.
The other part of the problem (apart from fretting and stretching of the rivets) with a single-skin aluminium monocoque is the basic ductility of aluminium.
Essentially, it stretches a bit in service, with the more highly stressed areas stretching a bit more than lower stressed areas, so that the whole structure can then 'oil can' to some degree (ie. localised and limited buckling of the panels to 'take up the slack', analogous to the way you can 'pop' the side of an old rectangular metal oil can in and out under thumb pressure). Honeycomb helps this, as it stabilises the panels against this localised buckling.
Of course, the other solution is to use a material that is not anything like as ductile as aluminium - for example fibre composites - but we probably don't want to go there.
ftaffy
posted on 13/6/16 at 11:22 PM Reply With Quote
True, didnt think of the skin stresses variation over the length of the body... was only thinking local stresses at the rivets being better spread by gluing.
Would be interesting to see that in an FEA form, guess i will fix up one of the simple skin bodies and get some framework in it and make a colorful picture to understand what is happening - note this wont actually give torsional strength or any useful number apart from see the high stress areas, my knowledge limits me to me single piece FEA, ie an upright.
Hmm too many design directions at once... need to quit my job and do this full time.
1. 24 spaceframe
2. 25 Mono
3. 49/25 FEA of ribbed semi-mono
4. Sandwich design options
5. Rolled outer skin vs box mono with slip over chassis
6. Selecting which Al to use (Been suggested 5052 but see that a lot use 6061. 5052 was noted by Lola builder as being too soft... Notes seem to say stay away from 2024 as its too hard to fold without cracking.) As this will drive the bend radius i can design with. Or make it a heavy weight and use mild steel and no rivets all welded design.
http://www.aircraftspruce.com/catalog/mepages/aluminfo.php
Will start knocking that list off this week hopefully and see what direction comes out
[Edited on 13/6/16 by ftaffy]
ftaffy
posted on 3/7/16 at 10:56 PM Reply With Quote
[img]https://racecarsdirect.com/content/UserImages/58843/390297.jpg?v=1[/img]
[img]https://racecarsdirect.com/content/UserImages/58843/390298.jpg?v=1[/img]
Hey Sam,
A question about the planks, after doing a wood mock up i can see using both methods but are the tops of the 'plank' just a AL U riveted/glued on?
Taffy
[Edited on 4/7/16 by ftaffy]
Sam_68
posted on 4/7/16 at 08:03 AM Reply With Quote
Dunno, is the honest answer.
The photos appear to show no joints, which seems to suggest that the 'planks' might be folded from a single sheet of alloy to form a continuous, deep inverted-U section, with the honeycomb and hardpoints bonded in afterwards, but it's a very long time since I've seen a FVL in the metal, and I really can't remember.
You might try asking around the FVL spares suppliers, or people still running them, or even drop Adrian Reynard a line?
ftaffy
posted on 4/7/16 at 10:05 PM Reply With Quote
Its not a big deal unless i find a place that sells planks perfect for my use...
In good news though i got to sit in my wooden tub and found out i cant reach the pedals, somehow added the pedal space twice to the length. Annoying mistake but cheap in wood offcuts vs anything else.
Also found a 110% tub with 1in extension to the lower U in the 49 makes it sit flush with the VW V6 rockers, though looks like the car will be running a 1in higher ground clearance due to the gearbox outputs. Considering the original was around 4in hopefully wont impact appearance with some creativity.
Taffy
rodoe
posted on 7/7/16 at 02:24 AM Reply With Quote
Hi guys,
I've had the same desire to build a lotus 25 style mono with a bike engine.
The engine is wider than the inner tub so will use frame at rear. After talking to
an Elfin Mono owner, he strongly encourage the rear frame idea as working on the
enclosed engine is a bugga.
I first got the idea after seeing the restoration of an Elfin Mono,
they look simpler than I thought they would be.
Anyway, www.bahnerengineering.com has a few pages of amazing quality
images of monocoques of all types and sizes.
After a bit of reading I was under the impression that 2024 T3 was the
way to go skin wise, using Cherry Rivets and then bonding as well. But you mention
other grades and that stretching may be a problem.
I'm wondering if the inner tub were honeycomb would that help (sorry, I am no engineer
and you seem to be so ).
You may also find this thread on uphill racers forum interesting. http://www.uphillracers.com/showthread.php/open-wheeler-build-6443.html
Sam_68
posted on 8/7/16 at 12:03 AM Reply With Quote
Originally posted by rodoe
I'm wondering if the inner tub were honeycomb would that help (sorry, I am no engineer and you seem to be so ).
Not me - dunno about Taffy! My main career is in architectural design - engineering design has always just been a sideline, for me (though structures are structures, to some extent - just that buildings don't move quite so fast ).
As I understand it, honeycomb helps a little with preventing 'relaxing' of the tub (though it's bonding as well as riveting that makes a bigger step), since it stabilises the skins against 'oil canning' - localised buckling of the skins that means the 'buckled' section is doing no work, which then turns into a vicious circle: the 'oil-canned' section does no work, so the neighbouring metal is worked harder and, being ductile, stretches a tiny bit over repeated loading cycles, expanding the oil-canned area, and so on, in circles...
My approach when I was looking at this sort of design was to opt for a V-twin, which is narrow enough to match the width of my fat arse. That was also partly on the grounds of weight and the fact that I don't like the stressy noise of 4-cylinder bike engines when combined with the short gearing of a car, though... but admittedly V-twins sound wrong if you want the scream of an F1 car.
Nice links, by the way!
rodoe
posted on 8/7/16 at 05:55 AM Reply With Quote
I have contact with one Elfin Mono owner who hasn't had his car long, but he knows another long term owner who frequently races his Elfin mono. He is a older racer who was quite a successful formula ford campaigner in his younger days so I am sure he will have an idea as to the subtle changes in chassis stiffness over the years he has driven it. I will question him.
Ensign F3 cars were an interesting transition from spaceframe to mono as seen in the photos from http://www.ensignf3.com/[url]
Sam_68
posted on 8/7/16 at 07:56 AM Reply With Quote
Not a single-seater, but the Andre/Reynard Inverter uses a hybrid solution too, of a very simple spaceframe, reinforced with stressed sandwich panels instead of triangulation to form a monocoque structure.
Lots of interesting drawings on the above link, and all free to download in both CAD and pdf format.
<<  1    2  >>
New Topic New Reply
