craigdiver
| posted on 17/10/16 at 06:49 PM |
Haynes spec wishbone jigs
Anybody got a set of Haynes spec wishbone jigs they would sell / loan / rent?
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
Talon Motorsport
| posted on 18/10/16 at 05:03 AM |
The book jigs are naff you are better off making your own from 25x25 box section and clamping the bush tubes in place using 20x20 and G clamps, it
also means every things stays clamped in place even when you turn it over. One jig will make all the wishbones by adding an extra bar.
craigdiver
| posted on 18/10/16 at 05:41 PM |
This is fantastic advice, what is the 20x20? (angle, tube, RHS) and is it through the bush tubes or on top clamping it to the 25x25 RHS frame?
mark chandler
| posted on 18/10/16 at 10:36 PM |
I made my jigs out of bit of MDF then screw blocks of wood to hold the tubes tight, run a bit of studding through where the bushes will go to ensure
alignment at this end.
Just tack weld then remove and seam weld.
If your chassis already has brackets on it then use the frame as a jig, if you still have to weld on the brackets then use the bones as a jig.
  NSF lower wishbone 23 Oct 2005
