Chris_R
| posted on 4/1/05 at 10:17 PM |
Steering Column Mounts
Does anyone have any photos? Big help if you do.
Chris.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
phelpsa
| posted on 4/1/05 at 10:22 PM |
I'll get some in the morning.
Mine are basically two right angle triangles with the column mounted to the back.
/__|
Like that.
Adam
Mark Allanson
| posted on 4/1/05 at 10:44 PM |
I think you already have an idea of my bearings, here is the supporting structure
Chris_R
| posted on 4/1/05 at 11:02 PM |
Cheers guys.
Mark, is there no end to your library of photos?
mangogrooveworkshop
| posted on 4/1/05 at 11:10 PM |
Close up
  Bushes to reduce bolt size
Mark Allanson
| posted on 4/1/05 at 11:37 PM |
quote: Originally posted by Chris_R
Cheers guys.
Chris, 1804 shots at the moment - and it still needs painting and SVAing
Chris_R
| posted on 4/1/05 at 11:44 PM |
I've got a few, but not that many. Mind you, I haven't finished the chassis yet.
phelpsa
| posted on 8/1/05 at 12:23 PM |
Here's how I did mine
andylancaster3000
| posted on 8/1/05 at 08:43 PM |
I must say Mr. Allanson, that is a mighty fine looking chassis you have made there. I do like the column support especially. Does that structure
above the drivers feet hold the master cylinders and pedal box? I can't quite make it out from the picture.
ned
| posted on 10/1/05 at 09:53 AM |
adam, aged 13 (or is it 14 yet?!) are you very short as your steering column looks to be at a very funny angle in the pic..
Ned.
beware, I've got yellow skin
Mix
| posted on 10/1/05 at 10:13 AM |
That air bag seems to have deployed aswell
Mick
phelpsa
| posted on 10/1/05 at 06:24 PM |
Ned
Mix,
Didn't you know that Tesco had just started selling a range of airbags?
DaveFJ
| posted on 11/1/05 at 09:09 AM |
just to add my 2 pen'orth......
I don't think that G clamp will pass SVA
Dave
Avoneer
| posted on 11/1/05 at 12:04 PM |
And i'm sure that silver grill stuff will have sharp edges - maybe some U trim will be the way forward?
phelpsa
| posted on 11/1/05 at 04:01 PM |
It doesn't have to pass SVA it's a race car
Avoneer, I have 3m of u-trim in a box somewhere, I think thats a good idea
Mark Allanson
| posted on 11/1/05 at 08:52 PM |
Thank you very much Sir,
Yes, the structure holds the complete sierra pedal box with the servo removed, the clutch pedal moved 1/2" closer to the brake - It works well,
a load of black lines all over our industrial estate to prove it
splitrivet
| posted on 12/1/05 at 11:55 AM |
That does look like one hell of a well engineered chassis Mark.Not going to mount a fifteen pounder on it are you.
Bob
Mark Allanson
| posted on 12/1/05 at 08:14 PM |
I know she is a bit heavy in places(57Kg without the floor), but I prefer that reassurance, and it will probably give a nicer ride
