New Topic New Reply
Author: Subject: Rippled Steel Floor - Welding Tip
ChrisS
posted on 6/1/05 at 09:01 PM Reply With Quote
All of those who have already welded in your steel panels and floors will tell you its pretty much impossible to get them welded on without getting a rippled effect caused by the heat distortion from the welding.
Theres no real trick to stopping this from happening, but there is a way to resolve this after fully welding the panel in.
Once fully welded find the high or low spot as near to the middle of the panel as possible, then using not too much power as to burn through the panel weld a spot making it gradually larger depending of the severity of the distortion in the panel. Once youve done this you should find that the once distorted panel is as tight as a drum.
Best of luck.
Digital Eyes - digital cctv specialists
www.digital-eyes.co.uk
phelpsa
posted on 6/1/05 at 09:13 PM Reply With Quote
Best of luck.
I might try that out.
Adam
Mark Allanson
posted on 6/1/05 at 09:24 PM Reply With Quote
Best of luck.
commonly known as heat shrinking, best done with sexy ahotalene, but a blowlamp will also do the job. Work inwards with a spiral motion, planish with a wooden mallet with a leather covered dolly underneath.
A lot or work, considering that only unlucky hedgehogs can see all your hard work
Alan_Thomas
posted on 6/1/05 at 09:29 PM Reply With Quote
No ripples in my floor but then I drilled 5mm holes every 25mm around floor and plug welded to chassis - no distortion and a quick dress with the grinder and it is as flat as the original sheet. - Alan
Chris_R
posted on 6/1/05 at 09:52 PM Reply With Quote
Why don't more people do that?
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
Mark Allanson
posted on 6/1/05 at 10:17 PM Reply With Quote
I plug welded mine, 8mm holes every 50mm, loads of distortion with 18g steel. If you don't get distortion with this thickness of steel you simply have not used enough heat to secure the floor
Chris_R
posted on 6/1/05 at 10:22 PM Reply With Quote
Mark,
Would you expect distortion with 16swg?
stephen_gusterson
posted on 6/1/05 at 10:31 PM Reply With Quote
well, i know my 16swg is correctly welded then!
dunno if thats a
or a
atb
steve
Mark Allanson
posted on 6/1/05 at 10:41 PM Reply With Quote
Mark,
Certainly, but it would be less pronounced
You will get distortion when using any flat plate, just look a a picture of a naval frigate, they are skinned in 1/4 plate
Pseudo7
posted on 6/1/05 at 10:49 PM Reply With Quote
"...drilled 5mm holes every 25mm around floor and plug welded to chassis..."
That's exactly what I was thinking of doing...shear loads will still be transferred as the plug welds are better in load transfer than fasteners, but not as good as a fully perimeter welded panel. Better than a riveted alum panel however.
Properly dressed out, should look prettier too. Just more work drilling all those holes however
What about stitch welding around the perimeter of the panel in 1" lengths, alternating side to side, inside tube edge, outside tube edge? Perhaps that would reduce/eliminate the warping? Similar to the pic attached (Ref. http://keith.miata.net/seven/flip.php?x=65)
I haven't welded any thin gage steel panels yet, so I don't have any experience. Rescued attachment 7_drivers_floor.jpg
Pseudo7...similar, but not authentic!
Mark Allanson
posted on 6/1/05 at 10:58 PM Reply With Quote
The floor in the image is at least 2mm thick as you cannot get pickled plate in anything thinner. The welds look excellent, helped by the thickness of plate
kb58
posted on 6/1/05 at 11:01 PM Reply With Quote
Another way is to bend up the edges of the floor pan 1/8" or so, and weld only those parts of it.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Alan_Thomas
posted on 6/1/05 at 11:08 PM Reply With Quote
Distortion is not an essential sign of good weld penetration, its a sign of too much heat in the same place. My floor is 16swg and a single plug produces no distortion. the secret is to weld one miss 3 weld one etc. By the thime you go back to weld the inbetween holes, again jumping over the gaps, the metal has cooled enough that the plug weld does not heat the surrounding metal enough to cause distortion. - Alan
New Topic New Reply
