Hugh_
posted on 5/8/17 at 05:46 AM |
Haynes/Saturn MX5 build parts
Ive had a change of heart on an unfinished project that I bought from eBay and have subsequently bought a load of parts for before discovering some
issues with the chassis. We have 2 young kids so I'm unlikely to have time to build a new chassis in the near future.
Im undecided whether to hang onto everything until I have time make a new chassis, or to sell the bits so testing the water to sell everything
together, ideal for someone setting out on an MX5 buid!
Update - I will split, prices added below. If any of them seem way out let me know.
Haynes roadster bodywork (all RAL2009 Traffic Orange except front arches in white): nosecone, bonnet, side panels, rear tub, rear arches, and front
arches. (everything except scuttle). There are 2cans of 2k RAL2009 for the arches. £450
Front and rear wishbones (to Saturn design) with poly bushes £90
Unopened Gaz shocks & C spanner.£250
o 14" Open 9.5" Closed shocks & 1.9" 350 Rate 8" Free Length Springs
o 12" Open 8.5" Closed shocks & 1.9" 200 Rate 7" Free Length Springs
Bolt kit for wishbones, shocks and hubs.inc if wishbones and shocks/springs bought together.
MX5 Front hubs and rear hubs £50
Roll cage homemade, bolt in cage to suit Haynes roadster, with top harness points welded in. £150
1.6 MX5 diff and crossmember, drive shafts and prop shaft (unaltered).
Fibreglass shell seats £175
MX5 loom and ECU
Polo radiation (new) £15
MX5 fuel pump and sender £30
Pedals (welded and powder coated), and brackets, brake master cylinder and reservoir, and Rally Design 0.7 master cylinder with integral reservoir
(for clutch as per Saturn manual) £75
Brake Calipers (assumed from a 1.6), and discs (rusty but look virtually unused). £40
Gearbox mount as per Saturn manual.£10
Ford escort mk1 steering rack with extensions which convert to MX5 balljoints (included), £100
MX5 upper and lower columns, including UCFL.205.14 support bearing as per Saturn manual, and polyurethane rack clamps. Column will need an
extension or lower part changing. £20
Rear diffuser in aluminium £50
MX5 1.6 engine (unknown condition) and gearbox £50
MX5 mk.2 1.8 dials £10,
MX5 mk.1 column stalk £10
MX5 daisy wheels and tyres (best consider them build wheels/tyres but the wheels might refurb ok) £50,
7 headlights chrome with some pitting, not E marked - £20
There is also a MX5 1.6 engine (unknown condition) and gearbox, airbox, manifold with oxygen sensor, various aluminium panels, a set of mk.2 1.8
dials, mk.1 column stalk, gear levers and knobs, handbrake lever and balance cable, MX5 daisy wheels and tyres (best consider them build wheels/tyres
but the wheels might refurb ok), steering column plastic cowl, hazard switch, header tank, and Chris Gibbs Haynes book.
Im near Tonbridge in Kent, I'll get some photos up later today.
[Edited on 6/8/17 by Hugh_]
shindha
posted on 5/8/17 at 06:07 AM |
Hi if you decide to split could be interested in the seats and polo radiator
nye
posted on 5/8/17 at 05:40 PM |
Interested in bodywork if break
Hugh_
posted on 6/8/17 at 09:49 AM |
Thanks for the replies. I am happy to split if all the big bits would go fairly quickly. Only one of those I haven't that someone hasn't
expressed an interest in yet is the cage.
Photos on Flickr.here
Chassis has obviously gone separately
furryeggs
posted on 6/8/17 at 12:35 PM |
What size is the rear diffuser.
cheers
Mudchute
posted on 6/8/17 at 02:44 PM |
Hi, can I have dibs on the shocks and springs please.
Hugh_
posted on 6/8/17 at 07:29 PM |
I will split, prices added in the original post, some of it hard to price, let me know if any of them seem high.
davidsurf-31
posted on 7/8/17 at 07:49 PM |
Hi Hugh, if still available wishbones, steering rack, shocks and pedals no offers price you are asking
Regarads
Hugh_
posted on 7/8/17 at 08:43 PM |
Shocks and springs have gone to mudchute,
Engine, wheels and polo radiator - Jrusselluk has dibs.
Wishbones, bolts rack, pedals, diff, shafts, hubs - Davidsurf-31 has dibs - deposit received awaiting collection in next 2-3 weeks.
[Edited on 8/8/17 by Hugh_]
Hugh_
posted on 7/8/17 at 08:46 PM |
cheers
Diffuser is 1030 x 250 x 97
davidsurf-31
Hi, will have diff and shafts and front and rear hubs if you still have them, and yes I will collect
davidsurf-31
posted on 7/8/17 at 08:56 PM |
Hi you have my number Hugh send us a message or give us a call and we can discuss collection
Thanks.
miskit
posted on 8/8/17 at 04:49 PM |
Hi
I'll take the MX5 mk.2 1.8 dials £10 if you can post please. I'll U2U.
Hugh_
posted on 8/8/17 at 08:30 PM |
quote: Originally posted by miskit
Hi
Hi that's fine your dibs, got your U2U, will check the dimensions tomorrow evening to see if it can send small parcel.
Hugh_
posted on 9/8/17 at 08:38 AM |
Hi
Dimensions work for small parcel, you have U2U
Hugh_
posted on 9/8/17 at 08:41 AM |
Seat dimensions
The underside of the seats, where they mount are 382mm wide and 390 long.
The widest point of the seat by the shoulders is approximately 420mm.
Hugh_
posted on 9/8/17 at 01:04 PM |
Bits remaining
The following bits are still left and some price reductions:
arches. (everything except scuttle). There are 2cans of 2k RAL2009 for the arches. £400
Fibreglass shell seats £175 (underside is 382mm wide and 390 long, widest point of the seat by the shoulders is approximately 420mm)
MX5 loom and ECU £30
MX5 upper column, lower column welded section of Sierra column, including UCFL.205.14 support bearing as per Saturn manual, and polyurethane rack
clamps. £20
Rear diffuser in aluminium, 1030 x 250 x 97 - £30
Mudchute
posted on 9/8/17 at 06:04 PM |
Hi Hugh,
What model mx5is that loom from please? Does it come with the immobiliser unit along with ignition barrel & key? (They're all integrated)
Hugh_
posted on 9/8/17 at 08:15 PM |
Just had a better look at the loom, it has been cut about. No sign of ignition barrel though intrigingingly I have a key! I'll add photos to
Flickr now but as it's not complete it can go free to anyone who wants to collect it.
dwebber597
posted on 11/8/17 at 11:34 AM |
Do you have any pictures of the bodywork?
Hugh_
posted on 14/8/17 at 03:07 PM |
1 bodywork photo below, more in the Flickr album accessible by clicking the photo.
Side panels and rear arches were unwrapped for the first time to photograph and came from Equinox in faversham earlier in the year.
The rest came with the kit on eBay, there are a couple of small marks on the nose come all but 1 should polish/wet and dry out, and one bubble on the
rear panel approx 3mm x 1.5mm. I had intended to cover this with the number plate. Photos of the marks in the album
Bodywork[
/url] by [url=https://www.flickr.com/photos/36385666@N00/]Hugh Gabriel, on Flickr
miskit
posted on 14/8/17 at 10:39 PM |
Dash arrived on Saturday, Thanks !
Hugh_
posted on 18/8/17 at 04:48 AM |
Price reductions on few of the larger bits
arches. (everything except scuttle). There are 2cans of 2k RAL2009 for the arches. Side panels and rear arches cost £370 from Equinox in Faversham
earlier in the year - £400 for all of it.
Roll cage homemade, bolt in cage to suit Haynes roadster, with top harness points welded in, nicely made and reasonably high to suit taller
driver. Plates for 2 fixings to chassis each side, and studs in the rear arms to bolt through plates added to the rear corners of the chassis.
£100
Fibreglass shell seats £140 (underside is 382mm wide and 390 long, widest point of the seat by the shoulders is approximately 420mm)
Rear diffuser in aluminium, 1030 x 250 x 97 - £20
[Edited on 18/8/17 by Hugh_]
24vseven
posted on 18/8/17 at 09:03 AM |
hi is the 382mm measurement the overall width of the seat or just the mounting base, sorry if i have overlooked the obvious
Hugh_
posted on 18/8/17 at 09:36 AM |
outside to outside of the base, as per the photo below
Untitled[
