Slimy38
posted on 11/3/19 at 11:28 AM |
Fuel tank sealer on new steel tank?
As per title really, is it worth using a fuel tank sealer on a new steel tank? Something like POR15 sealer? It will be pressure tested for leaks etc,
I'm just wondering from a 'belt and braces' approach.
posted on 11/3/19 at 03:15 PM |
Are you concerned the tank has a leak?
Slimy38
posted on 11/3/19 at 08:25 PM |
Nope... well technically it has no sides at the moment, but when it's finished I'll be doing a pressure test to check for leaks.
posted on 12/3/19 at 10:03 AM |
Can you not do the pressure test first and then deal with any leaks found?
It'll surely only be welded joints/seams that'll leak so see what happens first with the pressure test before adding stuff that may be
unecessary.
(I've never fabricated a fuel tank myself so there may be more to it than I'm aware of)
Mr Whippy
posted on 12/3/19 at 12:18 PM |
I wouldn't bother, unless your welding is really bad it should be fine and if your welding is that bad maybe you should get someone else to weld
it in the first place. Relying on a sealer to fix porous welds is really just adding a potential for leaks in the future.
I know 7's are all about lightness but for me given the rather flamey nature of petrol and the tank being right behind your head in a 7 or right
above you head in a roll over... the penalty of a few extra kg's for a sturdy 2mm steel tank is worth it in my book and also a lot easier to do
nice welds with. Do mind to weld in a couple of baffles in there first if you want to go round corners. imo the location and normal design of the fuel
tanks in 7's is one of their weakest points.
