New Topic New Reply
Author: Subject: Its wider but fits the std nosecone
omega 24 v6
posted on 29/1/05 at 04:23 PM Reply With Quote
Ok if I decide to build the MC sorely 7 +442 am i right in saying a std nosecone would fit. Also fitting a capri axle which is 4" wider than an escort. So will the front wishbones need to be altered i.e.lengthened to suit the rear axle track. As a matter of interest will this allow me a greater choice of seat types and has anyone sourced a windscreen set up for this that can be fitted after the sva. I still can't decide which one to build guys i want the room but not necessarily the hastle of sourcing one off parts.
posted on 29/1/05 at 06:54 PM Reply With Quote
It seems a lot of Capri axle are only 2 inches wider than an Escort, some Capri axles are 4 inches wider as are MK3+ Cortina.
For suitable wishbones see GTS, MNR and MK websites.
omega 24 v6
posted on 29/1/05 at 11:03 PM Reply With Quote
Sh*t i thought i had it sussed. I still reckon that 442 may be the way to go as it would allow a chice of seats and all of the engine options i have considered. You could be right about the capri axle as i have just measured a half shaft and its only 1" longer than the escort one.
dozracing
posted on 31/1/05 at 08:21 PM Reply With Quote
If you look in the GTS section of the forum you'll see a discussion about some off the shelf wide bodywork we are now doing for the McSorley builds.
Everything from wishbones to dedion axles are also available too.
Kind regards,
Darren
omega 24 v6
posted on 31/1/05 at 10:15 PM Reply With Quote
cheers darren
New Topic New Reply
