New Topic New Reply
Author: Subject: Tube thickness Haynes chassis
dyno
posted on 2/11/20 at 10:11 AM Reply With Quote
Hallo to all.
I'm new on this site and have plans to build a Haynes Roadster using their book and plans.
Unfortunately one thing is not fully clear to me. The main tubes are 25x25mm 16swg. We use metric sizes in Belgium, we have 25x25x1,5mm (wall thickness 1,5mm) or 25x25x2mm.
As far as I can find out, 16swg is 1,626mm. We don't have 1,625mm wall thickness. It's 1,5mm or 2mm
To cut it short, what's the wall thickness of tubes most builders are using?? 1,5mm or 2mm ??
thanks in advance
Dirk
40inches
posted on 2/11/20 at 10:23 AM Reply With Quote
1.5mm is the normal gauge
dyno
posted on 2/11/20 at 10:30 AM Reply With Quote
Thanks a lot
That's quite thin wall stuff. I really thought it would be 2mm.
Are these chassis strong enough to handle high power outputs in standard form?
40inches
posted on 2/11/20 at 10:56 AM Reply With Quote
2mm would be overkill and very heavy.
The Jag V6 in mine has 270 ish BHP and the chassis is still in one piece
dyno
posted on 2/11/20 at 11:00 AM Reply With Quote
Nice build car
I like the air outlet's. Was it home build or can you order them ?
40inches
posted on 2/11/20 at 11:07 AM Reply With Quote
1.2mm ally sheet, easy to fabricate and they really work well. They also let air in at the front
https://www.locostbuilders.co.uk/photos.php?action=gal&user=40inches&folder=AJ30
dyno
posted on 2/11/20 at 11:13 AM Reply With Quote
Nice done
posted on 2/11/20 at 01:00 PM Reply With Quote
1.5mm wall thickness is the standard wall thickness. Strong enough chasis and easy enough to weld. 2.0mm wall thickness will make for a heavy chasis and more effort to weld as well.
big_wasa
posted on 2/11/20 at 01:10 PM Reply With Quote
Ive seen some daft power and torque figures put through a book chassis.
If you are going really daft there are some bits you could beef up with extra triangulation.
MikeR
posted on 2/11/20 at 01:34 PM Reply With Quote
As i understand it (and backed by the link here) 16 gague tolerance is between 1.4 and 1.6mm steel. 1.5 being average.
(linky - https://www.engineersedge.com/materials/sheet_metal_gauge_tolerances_chart_13178.htm)
1.5mm steel is therefore what you want
procomp
posted on 2/11/20 at 03:54 PM Reply With Quote
As above.
Check with your supplier EXACTLY what he is supplying and measure it to make 100%.
The tolerance on tubing is not good these days as they roll material to the EXACT min tolerance.
16g usually comes as 17.5G thees days and if you order 2mm you may find it is actually the equivalent of 16.5G which is what most are now using as GENUINE 16G from quality suppliers is now very expensive.
For RACE chassis i order 1.5mm BUT that can end up being as thin as 1.35mm. No problem on a race chassis with all the extra bracing and full rollcage Etc but for a std type road chassis it will lead to issues.
dyno
posted on 2/11/20 at 05:48 PM Reply With Quote
Originally posted by procomp
As above.
That's indeed what I see here, 25x25x2mm is in reality 25x25x1,8mm. Reason why I thought it was 2mm I had to order.
PS: do you build you road chassis out of 2mm and the race chassis only in 1,5mm ??
dyno
posted on 3/11/20 at 01:24 PM Reply With Quote
BTW, does anyone has the correct weight of a full Haynes Roadster chassis, build with 1,5mm (16SWG) tubes. Less wishbones etc.. bare chassis ?
thanks
Dirk
New Topic New Reply
