jonbeedle
posted on 31/1/05 at 02:59 AM |
RS 2000 Engine mounts
Hi all, I'm new here and this is my first post, but I guess it won't be my last! I am at rolling chassis stage building a
'book' Locost and I wondered if I can fit Ford Escort Mk 2 RS2000 engine mounts. The plates are welded to the bottom of the chassis as I
was going to fit modified Sierra mounts but I have a Mk 2 Escort 1300 crossflow engine which I'm now planning to use. I really need to know if
the holes in the RS mounts will line up with the ones on the engine. If not, can anyone suggest which mounts would be best?
Jon
A fulton
posted on 31/1/05 at 08:07 PM |
RS mounts
No RS mounts will not fit on to a cross flow
RS mount are alloy
You will have to use the 1300 steel mounting and cut and weld ot fit your chassis
good look
magic55
posted on 1/2/05 at 10:02 PM |
Hi
Im pretty sure that you can use the alloy rs engine mounts on your x-flow, because you use them in x-flow escorts to alter the engine position
slightly when fitting type 9 'boxes.
Dont know if theyll line up on the chassis though.
cheers Jake
jcduroc
posted on 1/2/05 at 10:19 PM |
Ford engine mountings
quote: Originally posted by jonbeedle
... but I have a Mk 2 Escort 1300 crossflow engine which I'm now planning to use. I really need to know if the holes in the RS mounts will line
up with the ones on the engine...
As far as I have seen so far both XFlow and Pinto engines have the same mounting holes in the block.
The standard XFlow mounting brackets are usable, the Pinto stays are not (too high).
Joćo
JCM
