mattplace
posted on 8/2/05 at 07:34 PM |
wishbone bushes and tube dia
where is the cheapest place to get poly bush type bushes?
also, what size tube did you use for the bush tubes. i've got 25mm by 2mm wall but thats different to gts bushes which seem the best buy to me.
posted on 8/2/05 at 07:38 PM |
when i was bone making, i bought the bushes, crush tubes and brackets all at once, to ensure they all fitted together. I went to MK (great service
BTW...), but im sure whichever company is local will have a competetive price. Its always possible to get stuff cheaper, but you could do a lot of
pissing about trying to get stuff to match...!
flak monkey
AFAIK the GTS poly's are the best buy. I certainly havent seen any cheaper anywhere else! The tube dimensions are on the GTS website with the
bushes (click on PDF)
Sera
http://www.motosera.com
mattplace
posted on 9/2/05 at 12:43 AM |
i would go for the gts bushes but can't get hold of the required tube - 1.25" 18swg.
may go and see how much an engineering company can manufacture some nylon bushes for tomorrow. a mate has told me about a good company and they like
cash!!
do you definately need crush tubes with the bushes? surely if the bushes are manufactured correctlyand the wishbone bush tubes are accurate, there is
no need for them???
flak monkey
posted on 9/2/05 at 01:01 AM |
The crush tubes are needed to allow free movement of the suspension. They are slightly longer than the pivot tubes on the wishbones, so when tightened
down securly the 'bones will still move.
Think thats right...
Sera
posted on 9/2/05 at 08:37 AM |
big disagreements on the length of the crush tube recently, i suspect the precise length depends on shore (hardness) of the bush. the crush tube needs
to be tight so it acts as the pivot, rather than the bolt. just how long and tight was the subject of heated debate. another advavtage to buying it
all at once!!!
James
posted on 9/2/05 at 09:02 AM |
<snip>
no need for them???
18swg seems a bit small for the wishbone bush (outer)tubes- you sure that's the right figure?
Even if it is, I can't see why you couldn't use thicker wall stuff- just reduce the length of the wishbone tubing length by a couple of
mm. Also, make sure your brackets are big enough for that size of tube to rotate freely!
Anyway, ask Darren to supply the bush tube with the bushes and crush tubes. I bought the entire lot from MK- made life much easier!
And yes, you definately need crush tubes with your bushes- otherwise what else would the bush rotate around... the bolt?
HTH,
James
Mix
posted on 9/2/05 at 09:19 AM |
Another consideration when buying bushes and tubes is the length of the bush tube supplied. Make sure they are compatable with the brackets you are
using.
Mick
blueshift
posted on 9/2/05 at 12:38 PM |
Don't panic: Doz at GTS will supply you the bush tubes you need, inner and outer, cut to length, for a small extra fee.
Hooray for Doz!
