kaymar
posted on 15/2/05 at 06:35 PM |
w/bone tubing&bushes
hi everyone i have sourced some 25mm 2.5mm wall thickness steel tube as used by hydraulic companies are there any bushes available tor the wish
bones. etc. or should i order a different tube size regards martin
having read this post what i should of asked really is what size bushes are available as i can get tube 25x2.5mm 22x2mm & and20x2mm so
before i comit can someone tell me of bush sizes and types and suppliers thanx
[Edited on 15/2/05 by kaymar]
andy9391
posted on 18/2/05 at 06:29 PM |
bush tubes
Robin hood cars do a complete bush kit with all the tubes and tophats you need priced at about £29 per set or £50 for two sets two sets will do the
hole car
clbarclay
posted on 18/2/05 at 07:41 PM |
Its generally best to get bushes first and tube later.
Better still is to work out exactly what bush and tube your going to use before buying either.
Most suitable bushes i've seen fit into a pipe of 21mm or 29mm internal diameter (or more likely is the imperial sized tube).
Dick Axtell
posted on 19/2/05 at 04:42 PM |
quote: Originally posted by kaymar
...as used by hydraulic companies.
MK himself advised me NOT to use hydraulic quality CDS.
Reason - Hydraulic CDS tube is heavily annealed, so it can be easily bent/curved and coupled up using appropriate fittings, for hydraulic
transmission, etc. This type of tube is usually employed as plumbing, in industrial hydraulic power applications.
You really don't want wishbones which will be too easily bent!!
BoL
[Edited on 19/2/05 by Dick Axtell]
Rorty
posted on 19/2/05 at 09:26 PM |
Definitely don't use odd ball off-cuts unless you are experienced in metalurgy and you know the exact composition of the material.
Just use mechanical tube; it's designed for general fabrication and is weldable.
Cheers, Rorty.
